Originally Posted by myriadmyriad
17x8 is perfect..... with 295/70/17 tires.. Big tires are tough on the suspension components. Aluminum wheels save a ton of weight,but they should be rated for 3000lbs load... You have to shop around for that rating. I like American racing or MT classics(Made by Alcoa)...
JM
"AND what would be better?"
I have run oversized tires on my current 4wd for close to 300k miles and have not had any suspension component issues.
Both the tires and wheels we have selected are rated far above the 3000lb load carrying you described, in fact even the standard equipment is rated above 3000.
We are going with :
American Eagle 186s 18x9 (possibly powder coated)
load cap 3450lbs
and
Cooper Discoverer STT LT 325/65/R18
35 inch w/ load cap of 3860lbs
We have heard about all the tire problems folks have had, and we want to avoid that. We do not want to be running at Max Load or Max pressure all the time.
I am more concerned about travtion in soft material than I am about rock-crawling. I don't think we will be doing a lot of rock crawling on purpose, but soft stuff is another story...
so by increasing the tire size to 35in and moving to 18 wheels we are getting a combined load carrying of 15440 lbs out of the tires.
So tell us
why this selection is a good idea?
or
Tell us
WHY this is a bad idea
Thanks,
Greg in Austin
