Old 11-01-2017, 02:26 PM   #21
Beached's Avatar
Originally Posted by mkkbven View Post
Beached, thanks for the reply. Power connections to the amp appear much simpler than I first thought. I’m looking at the Zapco ST-64D.BT. It’s much less powerful than the 204, but should be more than adequate for me.
When you reference midship speakers do you mean in addition to your front and backs? Or did you decide to delete the backs? I’m considering installing some 6x9 3-way speakers in the back ceiling just below the penthouse. I also plan to pre-wire the space below the passenger seat for a powered subwoofer, but will wait and see if I feel it is needed before I pull the trigger.
My speaker set up is:
6.5” Focal Expert separates up front (tweeters are in pods on the pillars, not stock location;
10” Morel Hybrid 2 way speakers in the roof between the doors and the penthouse opening. It was a passenger van so I already have extra stock speakers locations in front of rear wheel area. I don’t need the extra volume, and, if in wired in parallel with front speakers, I wouldn’t be able to fade to just front or rear.
The ST-204d amp is more then necessary in the van, but the system sounds effortless and clear when playing louder for an outside gathering.
Beached is offline   Reply With Quote
Beni
hildems
Margot
FCAshevlle
