Originally Posted by SierraHawk
Hi Twoxentrix, My bump stop sits 1" above a heavy piece of rectangular tubing that Heber welded onto the U bolt plate. Did you have to remove the rectangular piece of heavy steel tubing? If so did you use a Sawzall or torch? How did you finish out the upper surface of the plate after removing the heavy piece of "tubing"?
I'm 'that guy' which chooses to have the work done for me. The guys at the Shop I use are gifted when it comes to projects and custom work - and trust them implicitly. If they did remove a rectangular bar, I see no evidence it existed (but then they would have left it no other way).
*My front sumo's have approximately 1.5" of travel gap before the plate makes contact with them.
Did you end out ordering the Blue or Black?
