There's no gasket....between the canvas and the roof is Butyl tape...several layers. It's like thick taffy.
If it doesn't leak I would tape it off..........it's a lot of work and some $$ to re-do the canvas to the roof.
If you want to remove the butyl joint, a guitar string works well to cut it. One person on the inside and one on the outside. Solid (not wound) G string or B string.
You can cut through the butyl and raise the canvas up to paint if you want; removing the roof is a fair bit more effort.
