I have a 1995 E250 and put on a 2003-2007 Ford Grille. Yes it is different. The 3 screws on top work but there is nothing in the area for the lower mounting/tabs to go into so the bottom of the grille is not attached. I have a front bra so the mesh holds the grill in. It looks like one would need to change the whole front black plastic piece going across the whole front of the van with a 2003-2007 or try to make some kind of adapter so it can be attached at the bottom which I have not done. Maybe you can figure out an adapter with an aftermarket Grille.
1995 E250 2x SMB White Contempo Top Custom SMB Interior 5.8L (351) 69K miles
Added Propane Tank & Propex HS2800/20 Gal Fresh inside/20 gal gray underneath behind axle
2.8K Onan/Porti Potti Shower Area/110V Digital Oil filled Electric Radiator Heater/Dynaglo for backup
Hankook Dynapro ATs 225/75-16 LRE
New to me 10/2008 - 2nd owner
