Old 02-27-2024, 09:51 PM   #1
Pimpon's Avatar
Pimpon Grille Frod E 350
hello I want to order a grille it tells me that it is for models 2003 to 2007 my ford is from 1995 there is a difference or not
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-02-2024, 12:25 AM   #2
Pimpon's Avatar
Hello can anyone tell me if the grille of an E 350 from 1995 is the same as 2003?
Old 03-02-2024, 07:13 AM   #3
1der's Avatar
Here is a picture of the backside of a 2006 grill. I know for a fact that a 2003 grille fits a 2002 van as a direct replacement.
The 1995 grille backside pictures I have found look a little bit different.
Old 03-02-2024, 07:17 AM   #4
https://www.sportsmobileforum.com/fo...lle-15864.html
Old 03-03-2024, 10:28 AM   #5
rnj
rnj's Avatar
I have a 1995 E250 and put on a 2003-2007 Ford Grille. Yes it is different. The 3 screws on top work but there is nothing in the area for the lower mounting/tabs to go into so the bottom of the grille is not attached. I have a front bra so the mesh holds the grill in. It looks like one would need to change the whole front black plastic piece going across the whole front of the van with a 2003-2007 or try to make some kind of adapter so it can be attached at the bottom which I have not done. Maybe you can figure out an adapter with an aftermarket Grille.
1995 E250 2x SMB White Contempo Top Custom SMB Interior 5.8L (351) 69K miles
Added Propane Tank & Propex HS2800/20 Gal Fresh inside/20 gal gray underneath behind axle
2.8K Onan/Porti Potti Shower Area/110V Digital Oil filled Electric Radiator Heater/Dynaglo for backup
Hankook Dynapro ATs 225/75-16 LRE
New to me 10/2008 - 2nd owner
rnj is offline   Reply With Quote
Old 03-27-2024, 12:59 PM   #6
Pimpon's Avatar
Well my grille has arrived
Old 04-27-2024, 02:47 PM   #7
i just install the same grill .
fits perfect. only 1 problem .you cant release the safety latch.!
i rigged a wire to come out of the grill to pull the latch handle..
DON W is offline   Reply With Quote
Old 04-27-2024, 10:50 PM   #8
Hi,
I'm looking at that grill for my 2007. Do either of you have a picture of it installed? Also can the FORD letter's be left off to help with cooling airflow.
Thanks
Besags is offline   Reply With Quote
Old 04-30-2024, 07:23 AM   #9
The FORD doesn't have to be installed , it comes with grill and you have to screw it from the back
Old 04-30-2024, 09:36 AM   #10
Pimpon's Avatar
I haven't done the assembly yet
Yes the Ford letters are an assembly or not it's up to you to choose I don't think it makes much difference to the cooling
