Old 03-07-2018, 06:56 PM   #1
Seat interchange
Greetings. Hopefully this is the proper forum.
Regarding the fourth gen, '92 - '14, econoline, will all stock front seats swap within this era?
Sub question is, Does anyone know of off brands or aftermarket seats that have the same bolt mounting pattern.
I tried the search on here as well as some minor googling.., but
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
regis101 is offline   Reply With Quote
Old 03-07-2018, 09:20 PM   #2
mikracer's Avatar
I have an '05 and put '14 front seats in. The bolt pattern is the same, but the power seat plug is different. I just cut one of the plugs off and used spade connectors to connect the wires.
Old 03-07-2018, 09:37 PM   #3
Thanks for the reply. I'm starting to look for options for our '98.
Peace, Regis
2011 Express 1500
Old 03-08-2018, 12:10 AM   #4
TomsBeast's Avatar
I think most of the econoline seats from the base up, are the same bolt pattern. The earlier bases, like my 96, have a slightly different bolt pattern where the base meets the floor (I'm not sure where the cutoff is).
I just did a low budget seat swap for my van last summer. I picked up a passenger side base from Ray (1Der on the forum) and a new set of leather 'take outs' from a Honda Odessey van, middle passenger seats, from a couple guys that are always at the Goodguys show swap meets in Pleasanton ($300/pr I think). But the Japanese seat tracks are a different width than Ford, and I had to do a fair amount of fabricating (cut, grind, drill and weld to fit, paint to match) to make them look and work like factory. They turned out nice, but it took me 8hrs per side.
The seats I took out, are aftermarket van conversion seats w/armrests, the type you see in 1990's motorhomes and conversion vans, blue crushed velvet. Those tracks adapted pretty well to the Ford bases.
The seats I took out are available in exchange for a 6 pack of beer
Old 03-08-2018, 08:28 AM   #5
bet on black's Avatar
i put seats from a newer sprinter in mine. had to do some minor fabrication to make it work with the stock base, but i love my sprinter seats!
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 03-08-2018, 06:08 PM   #6
I'll be diving into this matter when the swivel bases arrive. My stock seats are still fine with the drivers side fabric starting to wear out. I'll be bending an eye to see if the pyro actuator is part of the seat or the base at that time also.
Peace, Regis
2011 Express 1500
Old 04-09-2018, 03:34 PM   #7
Got any pictures?
riceburner is offline   Reply With Quote
Old 04-09-2018, 06:31 PM   #8
I put seats from a 2017 E series in my 2003 without issue.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 04-10-2018, 07:38 AM   #9
The pyro actuator is screwed to the seat. I think it's a torx, but unbolts easily; it has a screw hole and a tab that goes into a slot to keep it oriented correctly.
Old 04-16-2018, 12:08 PM   #10
Do you have any photos of the plugs and which colour wires go where?
I'm about to do the same, putting '14 power seats in my '02. The wires on the base of the '14 seats are simple enough but the power wires from my '02 are MIA. At one point the converter bundled up a mess of unused plugs and stuffed them in the B-pillar. I'm just trying to figure out which plug out of the 6 or so various shapes belong to the power seats.
kevman is offline   Reply With Quote
