Extensions reduce the capacity of your receiver hitch, by a lot, if you are considering a heavy trailer & tongue weight.
A weight distribution hitch & sway bar set-up will give extra lentgh and more weight carrying capacity. And keeps your vehicle from 'bucking' over bumps.
I had clearance issues also. Couldn't turn but a small amount.
Still tight but doable, thats almost a 90 degree turn.
Another option is a rotating/folding trailer jack I guess.
Yes! Or a D/C electric one with no external handle. Like maxacceleration's
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
He is talking about the one in the picture 2 posts up.
My new van is on a car carrier as I write this headed for Asheville NC and a date with Chris at Ujoint. I'm building a 4x4 extendend van to pull a 8000 lb travel trailer. Currently we own a 4x4 class C. We live in our unit 3 months a year currently, soon six months a year. We want to move to a base camp strategy with a basic van camper for short term rustic camping and exploring. Anyway, let me get to the question. We have the van spec'd out to have Aluminus bumpers front and back. Our current unit has an Aluminus bumper and we love it. We are worried about the clearance between the spare and the propane bottles as well as the power jack. The van is being built with a six inch lift and 35" tires. Will a deluxe box fit with 35" tires? Are the boxes bolted on? Can they be removed or added latter? Will the box stick out further than 35" tires which are 12.5 wide I think? Anyone have an Aluminus bumper without spare or box? What does it look like? We understand the solution is a weight distributing hitch set up. Will we be able to use a drop ball and weight distribution set up? Too many things to think about... Ideas?
Jim Grant
2006 Quigley class C Rv
2006 E350 EB 6.0PSD
Yes, the WD hitches are adjustable, but for that much lift you will probably need a longer drop-shank. Also try to order the longest version available to give you more turning clearance.
I can not post a picture at this time because my trailer is at my shop 20 miles away. I just swapped the propane bottles with my dual batteries. The 35 spare tire on my Aluminess clears the batteries and come close to the propane but still has a little clearance. I use a Henley Arrow hitch system and not sure if that lengthens the distance but try the bottle/ battery switch.
