Thank you for all the helpful replies gentlemen.
I towed my trailer yesterday minus the propane tanks. No squat with a 1 ton & airbags. Pulls well.
I also found a good hitch/welder/fab man.
We noticed yesterday that nearly all vehicle mounted receivers (Ford, GM & Dodge) come out flush to the bumper.
Mine is inset 3". Grrr, why me...
MY Ford dealer says there is only one receiver. They didn't try too hard looking into it.
I'll look into an aftermarket extended receiver as spurious posted on Putnams receivers.
The WD hitch may be used merely for the extra room (I hear I can use the hitch portion only to gain length?, and save $)
I can swap tanks & batteries to make mucho room - if it can stay legal.
I can drop the batteries with the tops flush to the frame and put the tanks above for the most space conservation.
I've got a plan!
Truly I would like to flip my handle on the hand crank as that rubs the tire raising & lowering the tongue foot.
Or electric motor.
Jeez, so many issues just trying to make this set-up go down the road...
I went with the Tango trailer (Pacific Coachworks) as the interior quality and tanks/insulation etc, was superior to many others.
Close even on the no tire side just pulling out of my storage slot.
Room to work with...
