I’m looking at another project and it might be time to let this one go. This 4x4 E350 is very offroad capable (35’s, 4:30 gears, rear locker, etc), it does great towing, and is ready to get out and enjoy. Van is outfitted with a queen size mattress, 175 watt solar panel, 95 liter Dometic refrigerator, running water, standalone diesel heater, etc. Extended trips off the grid are comfortable, and not a problem!
I have owned this van since 2017 and have all maintenance records since purchase at 135k miles, when body was removed for a Bud’s Diesel Bullet Proofing. Bud’s work included rebuilt heads, ARP Head Studs, Sinister Diesel coolant filter setup, etc. 4x4 drivetrain was removed from a low mileage 2015 F250. Drivetrain wise, the transmission is the only thing factory OEM. Brakes, driveshafts, etc have all been upgraded. Lots of time and $$ invested, see below for more detail.
The van had roof racks in the past and there is rust where the brackets mounted to the gutters, primarily in the rear passenger area (shown in pics). This caused some body rust in the passenger rear quarter and over the passenger rear wheel well. There is rust around the rear 3rd brake light and over the windshield (all the common areas for these vans). The roof could be patched or might be a good candidate for a hard top or pop top install? I would obviously be asking for more $$ if the body was perfect, and I have tried to price it accordingly for an as-is sale.
I’m keeping the personal camping gear shown in rear storage drawers, otherwise what you see is what you get. I do have a dual steering stabilizer and a HD trans cooler that will go with the van. Both are brand new, just have not had time to install. Van is currently registered as an RV in California.
Asking $33.5k or Best Offer.
Van is still loved and being enjoyed. I will continue putting time and money into it if I don’t get a reasonable offer.
MG Metalworks 4x4 Conversion
• 2015 Ford F250 Axles with 4:30 Gearing (< 20k miles when installed)
• Full Float Sterling 10.5 Rear Axle w/ Factory Electronic Locker
• NV273F Transfer Case with 105k miles - Electronic Shift On the Fly (ESOF) Conversion by Agile Off Road
• Agile Custom Rear Springs with 5.5-6" lift over stock (No Lift Blocks)
• Agile Custom Valved Fox 2.0 Shocks
• Custom Heavy Duty Front and Rear Driveshafts
• RuffStuff Heavy Duty Replacement Front Diff Cover
• 35” K2’s on Method Wheels (5 Full Size Wheels/Tires)
• Kelderman Super Duty Dual Steering Stabilizer Bracket (new not installed)
Engine & Bullet Proofing
• Bud's Diesel Bullet Proofing was done at 135k miles. Body off for new heads, ARP Head Studs, Sinister Diesel Coolant Filter setup, replaced driver's side injectors (passenger side was done previously), oil cooler, new body mounts, etc.
• Engine monitored by Edge Products CTS3 84130-3 Touch Screen OBD2 Monitor Gauge Scanner & EGT Probe.
• Start batteries, starter, alternator, radiator, etc have all been upgraded or replaced in the last 2-3 years.
• DC Power 270 Amp Alternator and Cable Upgrade from FICMRepair.com
• Upgraded Start Battery Cables to 2/0
• Mahle 6.4L Powerstroke High Torque Starter from CNC Fabrication
• The van is completely stock tune wise and always has been, ready to pass CA Smog.
• Mileage: 163,091 (Drivetrain is < 40k miles)
Solar, House Battery & Refrigerator
• Firefly 12V Group 31 AGM Deep Cycle Foam Battery
• 175 Watt Solar Panel
• Dometic CFX95DZ Refrigerator included (New 06/2023)
• Renogy 50 Amp Solar Controller – Charges House and Start Battery
• Renogy Battery Monitor
Maintenance & Upgrades
• Swiveling Front Seat Mounts – Driver and Passenger Side
• 40 Gallon Aero Tech Fuel Tank – Provides ~500 Mile Range
• Diesel Heater – Plumbed to Aero Tank
• Afterburner Upgraded Controller for Diesel Heater
• Running Water – 12V Water Pump with 5 Gallon Jerry Can Feed
• Portable Propane on Demand Water Heater
• Thinsulate Insulation on Walls
• 6.4 Transmission Pan & Filter Upgrade
• Updated Halogen Headlights
• Wilco Hitchgate Max Tire Carrier
• Reese Towpower Rear 96926 Class V Hitch
• Draw-Tite 65053 Front Mount Receiver Hitch
• US Cargo Control - L-Track, brackets, etc. – Spaced for Sienna Seat Brackets on Floor
• Rigid Industries D-Series Dually 20 Deg. Flood LED Light 21211
• Pop Out Windows – Side & Rear
• OEM Tow Mirrors
• Door Talon
• Rear seats are factory Tahoe seats that fold down. Seats have factory shoulder harness and are secured to the floor mounted L-Track.
• Queen Size Mattress fits with ~12” width to spare on Bed Platform with Seats Folded Down.
https://www.dropbox.com/sh/ezlc2dzys...s4syKWk7a?dl=0
https://www.dropbox.com/s/svnfp0324sotwmn/1.jpg?dl=0
https://www.dropbox.com/s/mjffp2ro562rqrj/2.jpg?dl=0
https://www.dropbox.com/s/ojt1sxn924lej7e/3.jpg?dl=0
https://www.dropbox.com/s/h0eav5dfzla9ss9/4.jpg?dl=0
https://www.dropbox.com/s/e3nwvzgvd0tmcve/5.jpg?dl=0
https://www.dropbox.com/s/cbltdbqibpnyyta/6.jpg?dl=0
https://www.dropbox.com/s/0g79ny1uz7udh58/7.jpg?dl=0
https://www.dropbox.com/s/thganwebpm1qwnv/8.jpg?dl=0
https://www.dropbox.com/s/cdlz8w4dw05hc7r/9.jpg?dl=0
https://www.dropbox.com/s/kdf8d6e4xy1uhe9/10.jpg?dl=0
https://www.dropbox.com/s/8wbpfk3pvbz071j/11.jpg?dl=0
https://www.dropbox.com/s/xz8sqkb7rxnx0rt/12.jpg?dl=0
https://www.dropbox.com/s/lqx7wovnuhcs9ei/13.jpg?dl=0
https://www.dropbox.com/s/civeorxcmzw2rp1/14.jpg?dl=0
https://www.dropbox.com/s/vbm3fpx1uvsyqq3/15.jpg?dl=0
https://www.dropbox.com/s/ylfu68m1jhrb89n/16.jpg?dl=0
https://www.dropbox.com/s/myg1yn0v6y9ewpn/17.jpg?dl=0
