Go Back   Sportsmobile Forum > Community Forums > Member Classifieds
Click Here to Login
Old 01-26-2024, 10:03 AM   #1
sale trade ford e350 Rear axle assembly 3.55 semi floating limited slip differential
Located in San Juan Capistrano.
Axle assembly for sale or trade (ammo or new solar panels or?)
Came off my 2006 ford e350 with 165k miles, axle code c9, 35 spline, Dana 60 semi floater with limited slip and disc brakes. Rotors and calipers included.
Has damaged right rear axle shaft and both wheel bearings. Ford service dept recommends changing all the bearings in the differential due to wheel bearing failure and metal in the oil.
$195 or best offer
Old 01-29-2024, 06:23 PM   #2
Price drop to $99
Old 01-29-2024, 07:45 PM   #3
Have you ever rebuilt the limited slip clutches and cleaned out the disk material in the gear oil?
I have a 2011 C4 (semi float, limited slip, 3.73 for greater than 8500 lbs) in my E-350 with 180 K miles.
I'm wondering how soon I should replace those clutches. (I have no history of this and it has many highway miles).
Did this contribute to your failed bearings?
Old 01-29-2024, 10:23 PM   #4
The only info I have is that the wheel bearings failed. I was pretty good at doing diff fluid changes too
Old 01-31-2024, 06:20 PM   #5
Update no longer available
