2011 Sportsmobile build, modified “50 Plan”
No accidents, meticulously maintained by single owner (records available)
Aug. 2023 appraisal certificate from America’s Automobile Appraisers will be provided to purchaser.
After 12 wonderful years of offroading, camping, boondocking and adventuring, life is taking us in new directions so it’s time for a new owner to enjoy this unique, loaded rig! Read on for customization details.
Contact 2vanish2023@gmail.com or 858-215-5128 to request a PDF with 95 photos.
Lift raises the floor to 37” off the ground plus full-float axle and Atlas transfer case that enables front or rear 2WD, 4WD High, or 4WD Low (3X gear reduction)
Manual ARB lockers
Frame-mounted Extreme Air Magnum 150 continuous psi compressor with air chucks in both bumpers
Aluminess roof rack with 520 watts of solar panels and 4 Maxtrax recovery boards
Two 4D batteries -- 440 amp-hour (5.3 KWHrs)
Xantrex 2000-watt true sinewave inverter/battery charger
12 AC outlets, 5 12-volt outlets, 3 USB outlets
Bluesky Solar Charge Controller 3024iL, and Solarboost power monitor
Aluminess front bumper with 12,000-pound Warn winch
Alumniess rear bumper with 9,500-pound WARN winch, spare tire, and large storage box
LED lights on the roof rack front and sides, and on the front and rear bumpers
Ultra clean interior has heated front captains’ seats, passenger seat swivels 180 degrees
Rear seat has 3 seatbelts
Olympic Queen size bed (67”W x 79”L)
Ceiling fan
10 LED light fixtures, very large storage shelves with cargo nets and 10 cabinets (two with locks)
Removeable carpet over Loncoin diamond plate floor
Windows screens, dual shades, and black-out curtains
46 gallon gas tank for a range of over 350 miles
16 gallon freshwater tank and a 16-gallon removeable freshwater tank with 12-volt transfer pump
10-gallon grey water tank
Cabinet with Thetford portable toilet
Flat plate water heater
Shower attachment at rear, and kitchen faucet extends for interior shower
Radio -- ICOM IC-706 MKIIG 100W HF, 50W VHF, 35W UHF transceiver above the dash with a fixed HF antenna with antenna tuner on the rear driver side and a 2 position (raised/lowered) Diamond VHF/UHF SG7500A antenna on the roof rack over the driver.
Garmin Inreach Explorer+ Satellite communicator for emergency use
Alarm with two key fob remotes
Public address system and 50W siren
ODBII monitor/display and DVR mounted on windshield
Train horn
Located in San Diego, CA
858-215-5128
