For Sale: $75 Located in Portland Oregon area
Adco SFS AquaShed RV Cover for Class B Motorhome w/ 24" Bubble Top - Up to 20' Long - Gray
Adco part number 12210
I purchased this new a few years ago and never used it, and I no longer have the van.
Fits class B or high top vans up to 20’ long.
this is a good deal if you need a cover for your camper van.
https://www.etrailer.com/RV-Covers/Adco/290-12210.html
Specs:
Application: Class B RVs up to 20' long with 24" bubble top
Dimensions: 240" long x 84" wide x 84" tall
SFS AquaShed Class B RV cover works best for short-term storage in moderate climates. Heavy-duty, 3-layer fabric protects against rain, snow, and sun. Contoured fit matches shape of your RV. Secures with cinch ropes and straps with buckles.
Features:
Cover protects your Class B RV from rain, snow, and sun.
Helps reduce the need for frequent washing, waxing, and exterior treatments
Prevents premature aging and helps maintain resale value
Contour-fit design conforms to the general shape of your RV
Top panel constructed of triple-layer SFS AquaShed fabric
Beads water on contact to prevent pooling
Guards against harmful UV rays that can cause cracking and fading
Eliminates black streaks and corrosion caused by air pollutants and rain
Side panels constructed of non-abrasive, triple-layer polypropylene
Breathes to eliminate moisture build-up, mold, and mildew
Lightweight material lets you easily lift and install over large vehicles
Zippered panels on passenger's side offer easy access to RV interior
Cinch ropes at front and rear of cover remove slack and reduce billowing
