Old 05-29-2020, 02:56 PM   #11
Twoxentrix's Avatar
Originally Posted by Glen View Post
I added a LED license plate lite & switch to the inside of the box ...
brilliant idea!
Old 06-04-2020, 10:24 AM   #12
Does Sam make a box that fits the Transit?
JT87 is offline   Reply With Quote
Old 06-04-2020, 10:36 AM   #13
Is there a ballpark number you'd share with us? I'm looking at more AGM batteries, but considering Lithium and the answer to me is $$ vs. $$$$.
Stewbie is offline   Reply With Quote
Old 06-04-2020, 11:19 AM   #14
northleftcoast's Avatar
I can quote you a price on a box for a transit. You’d just have to figure out the size that would work with the floor of the van. If you send me some pictures of the underbelly I can help you work through what’s possible.
Sam
2003 Ford E350 PSD, EB Cargo, Quadvan 4x4
northleftcoast is offline   Reply With Quote
Old 06-04-2020, 11:30 AM   #15
That's nicely done and very handy!
jstratford is offline   Reply With Quote
Old 06-04-2020, 11:59 AM   #16
Thanks, Sam.
I'll get under the Transit and shoot some photos with (rough) measurements.
One issue on the Transit is the structural frame member "in the way" of where the box would live.
Some folks have cut this structural member in order to fit a generic Sprinter box into the Transit. I'd rather avoid cutting the frame, and instead install a box that is "notched" around the existing metal.
Notching would reduce the volume of the box slightly, but would also provide a partition within the box. On the downside, I suppose the fabrication of a notched box would be more complicated/expensive.
Old 06-05-2020, 10:33 AM   #17
Can you describe why you modified the Ujoint skid plate? Was that the only option? Is there and alternative? Just kicking around on myself but had a few questions
wgchristman is offline   Reply With Quote
Old 06-05-2020, 12:06 PM   #18
freeagent's Avatar
Do you mind sharing where you tapped into power for the light? That's a great idea.
2005 E350 4x4 V10
freeagent is offline   Reply With Quote
Old 06-05-2020, 05:33 PM   #19
Glen's Avatar
The skid plate is bent upward at the front and back of the plate. The lip is about 2" tall. The underfloor storage box sets so that I had to cut/grind off the lip at the back of the skid plate.
The second part of the modification was due to me incorrectly measuring the depth of the space for the box. I had Sam make the box 2" shallower than his standard size. I didn't account for the nuts that are welded on the underside of the side rails that the skid plate bolts to. If I would have had Sam make the box 2 1/4" shallower, it would have fit perfectly. All I had to do to fix the problem was add 1/4" steel shims between the frame rails of the van and the side rails that hold the skid plate. This dropped the skid plate the extra 1/4" I needed to make it fit.
I took a couple of pictures, but didn't post them because they came out too dark. If my explanation isn't enough help, I can light the underside of the van up and try taking a couple of pics.
Friends Don't Let Friends Do Stupid Things Alone
Glen is offline   Reply With Quote
Old 06-05-2020, 05:43 PM   #20
Glen's Avatar
Luckily, the guys at CCV who installed the penthouse top put a fuse block with a couple extra ports at the rear passenger side of the van. I pre-wired and mounted the light & switch prior to installing the box. I left the wires long enough to run up through the floor of the van and to the fuse box via the same wire loom that CCV installed for the fuse block. It went through a rubber grommet already in the floor of the van, I'm assuming for just such a thing.
