You have a couple options.
1. Upgrade your stock brake parts (they will not fit a 4x4 axle) $
2. Buy a 2008 or newer van twin I-beams, hubs and brakes (larger from the factory.
Your Weldtec lift prolly won't work with the new I-beams, but I don't know that for sure. $$
3. Buy a MG kit and only install the front axle and just call it a work in progress. Your current wheels will not fit the 2005 and up 4x4 bolt pattern, the newer the 4x4 axle the bigger the brakes, They are all bigger then what you have now. But you already have the rear lifted $$$
4. Buy U-joint kit and go full in for a 4x4, your wheels will work but the biggest $$$$
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
