Old 06-30-2022, 08:40 PM   #1
catalytic converter guard
Well with all the news about cat theft and having a bit of spare time some rebar offcuts and the wish to cover myself in molten weld sparks I created this underbody art.
It might not be pretty but it might divert some low life to another vehicle. It is fully removable if you know how and although a combination of rebar and an old winch cable is passable.
Comments are welcome but bear in mind I have at least $2 into this project.
IMG_20220630_123505089.jpg   IMG_20220630_122111712.jpg   IMG_20220630_111315983.jpg
asgard is offline   Reply With Quote
Old 06-30-2022, 09:43 PM   #2
simplesez's Avatar
I'm going with...that is the best cage I've seen on the internet yet!
Old 06-30-2022, 11:25 PM   #3
I have to agree. And the best attitude for a project!
Twindaddy is offline   Reply With Quote
Old 07-01-2022, 03:44 AM   #4
marret's Avatar
Looks like it should be a visible deterrent in addition to actual. Nice.
Chris
Old 07-01-2022, 06:49 AM   #5
Excellent. Makes me wish I could weld.
Old 07-01-2022, 07:11 AM   #6
Twoxentrix's Avatar
That’s bound to inspire others!
Old 07-01-2022, 12:07 PM   #7
Me too........I have a welder......kinda like buying a gym membership.
Nice job! looks very robust. Are the back ends bolted down too?
Old 07-01-2022, 01:30 PM   #8
The passenger side has 3 mounting points and the driver side 2. I drilled through the gearbox cross member and that gave me a lip to rest on and stops the guard from being dislodged without the correct unbolt sequence.
Old 07-07-2022, 03:58 PM   #9
rt66paul's Avatar
You should use a couple of different size bolts that are recessed(so they can not be ground off easily). The different size heads mean a change of sockets to remove the cage. The more time it takes, means the thief will quit to look for easier pickings.
rt66paul is offline   Reply With Quote
Old 07-07-2022, 04:53 PM   #10
The unit is held on with concealed bolts of 2 different sizes,on the cross member I used a non-standard cap screw. I am looking for why bother at all, rather than let me check what type of bolts are used. It was done as a deterrent not a challenge but very good points.
