Originally Posted by Ryan89
Manual Pop Top - with no helper springs
But it takes 240lbs of force to lift the roof the first 6 inches, then tapers off as it gets higher.
My main questions are
1. Can I safely tension the main springs by 5 links or more? Most I have seen on forum has been 4 links and I dont want to damage the mechanism.
2. Has anyone retrofitted the helper springs and the coverplates to an older van that didnt come with them? If so any specs of the springs and photos of the cover plate setup would be appreciated!
The helper springs help for those first few inches of up/down travel for the roof. Unforch the geometry of the scissor type mech means that the horizontal springs don't apply much usable force when the top is fully down.
There is lots of info here on the helper springs:
https://www.sportsmobileforum.com/fo...ed-5080-7.html
Post a few pics of the area in the channel behind the crossbars....where the helper springs sit in the newer vans. If It's the same, there's no reason why you can't put helper springs in there.
You need the cover plates to retain the springs in there when they are compressed. Otherwise they can sproing out at very high speed and injure/kill someone or blow a hole through your canvas. The cover plates also provide the end stop for the helper springs so they are not acting on the very end of the channel.
Have you seen my thread on replacing the helper springs with gas struts?
https://www.sportsmobileforum.com/fo...gs-1084-7.html
I've been running this setup for years, much better than the helper springs, although I've had to replace a few struts over the years due to gas/oil leakage, but McMaster has been happily giving me free replacements.
Since you have sleeved your crossbars you can take up more links in the extension springs, however at some point the roof will shoot up fast after the first few inches and you be hanging with all your weight from the handles to try to get it down. With 5 links you may be close to that already.
