Old 11-13-2022, 06:03 PM   #1
Old Worn out Dog House Latchs
I've got a want to get dog house latches that hold more tension. My current ones aren't under much tension at all.
Anyone gone down this road?
I've considered moving the whole latch rearward.
desertsherpa is offline   Reply With Quote
Old 11-14-2022, 07:13 AM   #2
Some are very tight and others not at all. Have you had your doghouse off a lot? Very few have. If you don't have leaks (engine noise or hot air) then you can assume the big bulb seal is doing it's job. My new to me van has basically no tension on these at all and it is weird but no leaks so I'm not worried.
Old 11-14-2022, 08:49 AM   #3
REDOVAL's Avatar
It would likely be an easier experiment to add more bend/bow to the hook arm. This would effectively shorten it and add more spring to the system and add validity to preloading the bulb seal more. Installation would be the same but removal could be more involved to get the hook out of the latch due to the angle change. Just a thought.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 11-14-2022, 10:37 AM   #4
Maybe find one at a wrecking yard? Looks like its riveted on - be sure to take your drill if you go.
Old 11-14-2022, 11:23 AM   #5
Scott
I may try bending them.
This is a newer doghouse and seal from the junkyard.
Old 11-14-2022, 06:21 PM   #6
I'm still curious. Do you have a leak/noise or are you just convinced that there is something wrong because they don't have much tension?
Old 11-14-2022, 10:47 PM   #7
I've got a noise issue that I'm looking to solve. It is a 6.0!!!
Old 11-15-2022, 09:10 AM   #8
gahamby's Avatar
Is this a discontinued part?
Perhaps something in this line would do.
https://www.mcmaster.com/draw-latches/
'07 GMC 2500 6.0
Old 11-15-2022, 04:50 PM   #9
I think your noise problem might just be that it's a 6.0l, Lol.
The older doghouses had two slots on the top latches so you could draw it in tighter but the newer ones (97 up) do not as far as I remember.
My 2011 just has one slot, feels very sloppy but is completely quiet.....but it's a V10.
Old 11-15-2022, 07:32 PM   #10
This should make a change:
I moved the latches back 0.5"
When securing the cover, you can feel the thing actually deform. 0.25 may have been a bit to much. However TIme will tell. I had almost 0.25" free play in both latches, and the spring assembly its self can take up the slack.
For future people, the latches are still available :
https://alliancebusparts.com/i-23809...ine-cover.html
Ford part # F2UZ-1510444-A
ClifFord
EliMakes
Dusty
capnkurt
