Old 07-22-2018, 06:45 PM   #11
Hmm must be a gasser! I get 4 or 5 hours from my 7.3 PSD. About 38 gallons but the last 5 take 15 mins. Longest was 6 hours.
vlamgat is offline   Reply With Quote
Old 07-25-2018, 04:00 AM   #12
Originally Posted by bet on black View Post
Do the models with factory rear ac have a different compressor and/or condenser? I would bet they don't. Maybe you could adapt an under dash style unit mounted in the rear and tee it in using a factory line set from a club wagon that had rear ac. It's a rabbit hole for sure, but should work.
Very very late to this thread, hope my input helps...........
The Club Wagon's with rear heat & A/C do indeed use the same compressor and condenser as the cargo version vans use What's different is the receiver/dryer and high pressure line from the condenser to the front evaporator have tee's built in that feed the rear evaporator.
Rear evaporator uses a thermostatic expansion valve, front uses the typical orifice tube. Refrigerant gas charge increases from about 44 oz of R134a to 64 oz.
Both heat and A/C systems as installed from the factory are pretty awesome IMHO. A few high-quality aftermarket systems exist but as has already been said adding A/C after a build-out is a deep deep rabbit hole.
Not good news I know but rear A/C can be a very big improvement for living creatures who ride in the back while traveling.
Old 07-25-2018, 09:30 AM   #13
Originally Posted by Idigdirt View Post
I had to mount a Honda 2000 on top of my Aluminess rear storage box. A short cable to the charging port. THat Honda will run for 2 or 3 hours under a load. Which is longer than I can run my SMB before I have to stop for fuel.
2-3 hours? That's weird. My Honda runs almost 8 hours under load but load is a relative term. Just what are you running with it to only get 2-3 hours?
