Old 04-25-2023, 05:43 AM   #1
Rear shocks
I have an 02 Quigley E350.I am changing to rear axle from a semi float to a full float, Quigley uses a welded piece on the axle side shock mount to be able to use the stock length shock absorbers.What shocks are people using to utilize stock lower mounts on lifted vans?ie; longer than stock shocks.
van 4x4 is offline   Reply With Quote
Old 04-25-2023, 09:54 AM   #2
REF
REF's Avatar
Send a message via MSN to REF
Rear shocks
Call Agile offroad for custom valved Fox shocks, get all 4 and the steering stabilizer if the budget allows, they will get you the right length shock that’ll go with your FF.
I had new beefier shock mounts welded in when I swapped in a FF, you won’t want to and don’t need those Quigley extensions with the proper length shock.
REF is online now   Reply With Quote
Old 04-25-2023, 10:46 AM   #3
1der's Avatar
One of the nice features of relocating the lower shock mounts to the higher position is more ground clearance at those two spots. That reduces the risk of taking out the lower shock mounts on a rock.
Old 04-25-2023, 01:00 PM   #4
When I upgraded to a full float at first I bought new weld on shock mounts in order to reuse the original Fox shocks, but since I had cooked them twice I decided to upgrade to remote reservoirs to get more oil and cooling. Since I was getting all new ones I decided to just use the original mounts. Depending on the amount of your lift, you need to cycle the suspension to determine the proper lengths. First jack the van up by the frame until the tires are off the ground and then measure the distance from the top stem mounting point to the center of the lower mounting bolt. It's a little harder to measure the full bump length, but I measured the static distance with the wheels on the ground and then added the distance to the bump stop, giving me the maximum compressed length. Then I went here to find the proper length. https://www.ridefox.com/family.php?v...+Top+-+Eyelet+
If you have difficulty finding exactly what you want, once you have cycled the suspension, give Fox's customer service a call.
What I later discovered was that there was not enough rebound dampening, and so I revalved them adding some stiffer discs and now they are perfect.
Beni
hildems
The Yeti
TexGX
