Old 10-06-2008, 09:58 AM   #51
SMB Outfitters awning brakets
Are there any other takers. I am going to fabrication today, so throw your name in the hat. I am going to have 10 sets made, so there will be extras for those of you that want them later.
Eli
2006 6.0L EB 4x4 Ford Transformer with custom rear platform bed, AKA The Sliver Fox, AKA The Sliver Bullet
PecksTank is offline   Reply With Quote
Old 10-06-2008, 06:32 PM   #52
SMB Outfitters
The order has been placed. 2 weeks for fab, a couple days for paint and then off to those that want them.
Eli
SMB Outfitters
Old 10-07-2008, 08:54 AM   #53
pjpvi's Avatar
Eli -
I'd still like a set.
Thanks -
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 10-07-2008, 09:56 AM   #54
I have frim orders for one set from the following;
pjpvi
msponer
jammyauto
adventureduo
calclimber
And possible orders from;
jage
daveb
If these are correct, then please pm me with you shipping address and I will send them as soon as they are done. You can send payment before or after to SMB Outtfitters, attention Eli @ 2010 Elizabeth Way, Santa Rosa, CA. 95404. The cost is $180 per pair. Thanks
Old 10-07-2008, 12:25 PM   #55
Greg In Austin's Avatar
I have been following this thread peripherally, but something just occured to me...
Do most folks have two or three connection points between van and awning?
Greg in Austin
Old 10-07-2008, 12:33 PM   #56
Re: SMB Outfitters awning brakets
pjpvi
msponer
jammyauto
adventureduo
calclimber
jage
daveb
Eli Will the brackets rest on the new plates that SMB installed? I can't pull those off w/o body work. Actually I would like to bolt up to SMB's plate through your plate. It would lift the angle a bit and your plate would have to be wide enough to get 2 bolts in while being narrow enough to fit between the four screws that hold SMB's plate to the body. Possible?
Dave
Old 10-07-2008, 01:36 PM   #57
Ours has three.
Old 10-07-2008, 02:21 PM   #58
I run 2 of my brakets. The Fiamma awining is designed to be straight. If you run 3 of any type of braket, you are trying to bend the Fiamma, which will not happen, so you end up putting stress on all the mounting points.
daveb, I am not sure. how wide are the SMB plates, and at what location are they. I have my breakets with in about a foot of the ends of the fiamma. They have marked areas on the back of the fiamma that they recomend ofr mount locations. I also have the 11 foot awining. Many of you only have a 10 footer. Hope this help, and I will post the exact width of mine when I get home.
Old 10-08-2008, 07:21 PM   #59
I check our awning install this morning... we have 3 brackets, and the awning is mounted straight. This mounting does not follow the curved side of the van.
I am out of town now, but will get pics when I am back in town.
The three brackets all look to be different to allow for the awning to be left straight.
Greg in Austin
Old 10-09-2008, 04:34 PM   #60
calclimber's Avatar
Heres a picture of the front mount. It rubs the door when I shut it. I would really like to do away with this mount or upgrade to something else.
Quality doesn't come in a twist off
Craig
05 EB 50 V10 4x4 Baja Tan
calclimber is offline   Reply With Quote
Vanny Devito
dick
PigPen
velo47
