Old 10-11-2008, 09:12 AM   #61
daveb, I messured mine yesterday, and they are 3 inches wide front and back. I hope this helps. My plates are desinged to clamp on, but I guess you could bolt through them. The problem with bolting through is that the van walls are very weak and will crack, this is why I went the way I did.
Eli
2006 6.0L EB 4x4 Ford Transformer with custom rear platform bed, AKA The Sliver Fox, AKA The Sliver Bullet
PecksTank is offline   Reply With Quote
Old 12-10-2008, 06:31 AM   #62
I know I'm a little late but was wondering if I could still get a set of brackets.
Thanks
Gary
2000 RB SMB 7.3 Converted to 4x4 in 2010!
2001 KTM EXC 520
2008 Ducati Hypermotard 1100
2006 YZ 250f
2011 Modded KLX 110
2009 CRF 150r
MTBGary is offline   Reply With Quote
Old 03-26-2009, 03:09 PM   #63
mjeffrey's Avatar
Re: SMB's solution for awning cracks
+1 - Eli, I'd love to buy a set of your brackets. If they're all gone and you're not planning on another run, perhaps you'd share your measurements with us?
Cheers!
Mike.
mjeffrey is offline   Reply With Quote
Old 03-26-2009, 05:08 PM   #64
Eli,
Sent you a email today regarding all this, I would like a few pictures, I know I'm late to the game, but hopefully you can still help out us late comers
Keep up the good work and again can someone post some pictures of the brackets on or off either way would be really helpful.
Cheers
Cheers,
Jamie
2006 E350 Quigley 4x4, building the conversion with the gracious help from the people on this awesome forum!
I'll try & post all of our progress on our family dream, when we have some.....
AdventureRider is offline   Reply With Quote
Old 04-07-2009, 02:42 PM   #65
Folks,
I have three complete sets left, one of which is spoken for by mjeffreys.
Adventurerider, if you go through the whole post, you will see pics of my van (sliver) as well as others that have used the brakets. Some have been slightly modified.
After this batch runs out, I can have more made, but I need the intrest to be there. It is a significant amount of dough to front. I am willing to do it if everyone wants them.
I have others that have expressed intrest ( jage, natank, angle, and maybe skywagon) and if you are serious, please post or PM.
Thanks
Eli
Old 04-07-2009, 03:08 PM   #66
mjeffrey's Avatar
Thanks Eli! I've sent you a PM.
Old 04-07-2009, 10:11 PM   #67
Eli,
Emailed you a few times after reading the thread a week or two ago, we're in, just give me a call.
My contact info is on the email I sent you, I look forward to hearing from you & getting our awning taken care of.
Thanks
Cheers,
Jamie
Old 05-15-2009, 06:03 PM   #68
mjeffrey's Avatar
For those of you using Eli's brackets - where did you drill through into the case? I'd like to avoid drilling into the wrong spot, if possible
Thanks!
Mike.
Old 05-16-2009, 08:19 PM   #69
Mike,
Place the awining on the brakets. There is a lip on the top of the Fiamma that the brakets fit into.
Open the awining all the way and support with the legs.
Drill the holes throught the awining case and the brakets, be carefull not to drill into your top
Insert bolt and lock washer.
Close the awining.
Hope that makes it easy to under stand.
Eli
Old 05-18-2009, 02:33 PM   #70
mjeffrey's Avatar
Thanks Eli! That's exactly what I had ended up doing. Brackets are holding up perfectly so far, 1000 miles of sometimes bone-jarringly bumpy freeway in the last couple of days.
Now in Fresno and happy for the shade of an awning! Poptop going on today
I'll post pics when we get back in a week or two.
Cheers!
Rosy
Isever
Zengi
Amy V
