Water tank plumbing and venting
So I gutted a factory-built SportsMobile to redo the interior. I'm about to put the water tank back in. I went back to the picture of the original tank and how it was connected. After looking at it for a while, I can't figure out how it is venting. Can anyone explain whether the setup in the attached image is good and how it's venting? The pipe in the lower left runs to the rest of the van, where it tees in a couple places to go to the sink, the water heater, and the fill inlet on the exterior of the van. I've read about a lot of people doing vent hoses / pipes that rise a ways above the tank and then go back down through the floor, which makes sense. I'm guessing it also needs to rise higher than the sink? I'll probably plan to do that if I can't understand the self-contained setup in this picture.
