Well I have been working a lot, and needed to work on a few things in the van. I am planning a big trip in the spring but I have a few things that I really need to get done in order to make it work for work off and on for the next few months.
I did get this installed this weekend.
I am pretty stoked because this stereo has Android Auto and can also act a s a media player for the whole Van. I have to do a few more things to it to get the full functionality out of it. this is the Head unit i Installed.
Pioneer AVH-4200NEX -- DVD Player, Android Auto, or Apple Carplay it also has an SD card reader and a 7 inch plus screen. It has a lot of other features as well but those are the main ones I am going to be using. The screen is big enough the passenger seat and second row could watch movies.
If you are installing it in an Econoline (mine is a 98) you will need a few other things.
Metra 44-EC18 18-Inch Antenna Extension Cable
Metra 95-5817 Double DIN Installation Dash Kit You will need to trim the top or bottom of the opening in the dash opening in order to get this one to fit but nothing to major.
Metra 70-1771 Radio Wiring Harness You can splice all the wires in without this but I prefer the adapter route.
RAYSUN 2 Meter HDMI and USB AUX Extension Panel Flush Mount In the left of my picture you can see the USB cable plugged into this. The spot where it is used to have a cigarette lighter and I don't need that so I pulled it out and then just reamed the hole out a bit bigger and this fit right in its place. The back of the stereo has 2 USB ports (#1 is for Apple and #2 is for everything else.) It also has an HDMI port on the back so you can plug a laptop into if you want or anything else that uses HDMI. Having them on the front makes them much more accessible and Android Auto requires a USB connection so it will be right there by my RAM Mount.
Now after looking at this I wish I would have gotten a similar one that has a USB port and an AUX jack on it. I think we will use the HDMI a few times but I would use the AUX more often. I will end up adding an AUX port somewhere on the dash but if you want to have them together this is the one to use.
RAYSUN 2 Meter USB and 2RCA to USB and 3.5mm Aux Dash Mount
I also decided to upgrade the speakers mine were pretty hammered. I got 4 for the moment. I will eventually want another set in the back by the bed but I am not sure if the will go in the rear doors or not. So I got these for the front doors, sliding door, and side panel.
Pioneer 6.5 Inch 3-Way 640 Watt Car Stereo Speakers Four | TS-A167
These make the speakers a bit easier to install if you still have factory speakers.
Metra 72-5512 Speaker Harness for Select 1989-Up Ford Vehicles Now there is an option to buy 4 of these but it costs more than buying two sets of two so remember to check that if you order them.
I also got a
PIONEER ND-BC8 Universal Rearview Camera This will be great especially after I have the windows tinted. I am having all the rears blacked out and the fronts as dark as I can legally go in Utah so the camera will be nice.
There was also a really good deal on this
Pro II Leg and Bar Kit by Kargo Master so I ordered it as well, it showed up yesterday and I was hoping to get it installed but I decided to swap out my damaged passenger door and fender instead and that turned into a bit more of a project than I planned so I will get it on this week hopefully and add some pictures of it when I do.
I really like the low profile look, and I have an idea of how to mount some solar panels and an extruded metal platform on it as well so I am excited to try that out.
