Old 07-09-2020, 06:36 PM   #1
200 Ah House Battery Recommendation?
Hi all -- I see a lot of great advice on batteries and isolators in this Forum and I'd appreciate your guidance on replacing our 12v 200 Ah house battery -which is clearly at the end of its life. I've started by looking at Mighty Max, Renogy, MK Batteries, and Deka -- but would appreciate your feedback and experience. The battery rides in a rack under the chassis -- located beneath the side doors -- so without dropping it I haven't been able to look at what kind of battery it is.
Thanks for any input. Rick
rickschwolsky is offline   Reply With Quote
Old 07-09-2020, 08:01 PM   #2
Jeffrey's Avatar
Is it a AGM 4D? I use Lifeline brand, was original to the SMB. On my 3rd unit now on my13 year old SMB.
Old 07-09-2020, 09:23 PM   #3
I also like Lifeline (worth the cost IMO) but there are several out there that might work well for you. Deka does make a good battery. The main thing is to make sure the new batteries dimensions give you a safe clearance in the battery box or even fit. Same with the type connectors, make sure it's a similar fit and you don't have to modify something.
Old 07-10-2020, 08:26 AM   #4
My mighty max 4d is holding strong. Had to bend my tray 1/8" to make it fit.
tortorelli is offline   Reply With Quote
Old 07-10-2020, 11:50 AM   #5
Thanks so much!
Thanks guys for the great advice -- it may be best for me to drop the battery tray and get a match that fits -- than to take rough measurements and keep my fingers crossed -- especially about the battery posts. very helpful!
Old 07-10-2020, 11:50 AM   #6
Thanks Jeffrey -- very helpful
Old 07-10-2020, 11:51 AM   #7
Great advice Dave -- thanks!
Old 07-10-2020, 11:51 AM   #8
Thanks a lot for your advice
Old 07-10-2020, 06:18 PM   #9
My cables are long enough, that no matter where the posts are, I could make it work.
Even with an exact measurement, don't put much stock into manufactures specs. They were 1/8" off on mine. Maybe you could call and have someone physically measure the battery.
Old 07-16-2020, 04:16 PM   #10
Thanks everyone for your great advice.
I ended up getting a Lifeline 200 Ah AGM replacement -- and after getting into it I discovered it's what my existing battery is now -- so it should fit perfectly. There aren't a lot of distributors here in Colorado -- and I didn't want to buy something this important through Amazon (at $799) -- ended up getting it from BD Batteries in California -- for $614 with free shipping. Learned along the way that Batteries Plus stores will let you bring in used batteries like these and will recycle them for free. Rick
Tags
house battery replacement
