Re: Are solar panels in the N.E. worth it???
Len,
the rigidity of the panel is probably similar to 1/8" ply. It is flexible, but not flimsy. I'd bet that you could simply velcro or use a thicker double side tape at the higher rib sections and then maybe put in fasteners at two corners just for added security without having flutter due to air flowing under the panel at the rib. If you felt that you needed to stiffen the leading edge, you could attach a 3/16"x1" aluminium bar across the top of the leading edge of the panel too.
I also saw a guy on an airstream forum/blog that built his own lightweight aluminum frames for use with the flexible panel which resulted in a lighter end product that the standard glass panel.
Even though I treat it as if it were very delicate the panel seems quite durable. I'm looking forward to getting mine mounted, but my application is similar to gcvt's so not much help for you.
Josh
