Old 04-13-2021, 05:32 PM   #1
FatLady's Avatar
Question Deep Cycle battery replacement recommendations E350 2009
HI I just sent a thread but I can't find it any more
I am looking for recommendations for a deep Cycle replacement Battery
Currently we don't have solar but we may get it later on.
our battery was replaced in 2017 but it keeps crapping out and draining and we don't know why ( she is plugged into shore power when we don't use her)
I would need to get input on shops who would also know about installing a new battery and how to configure the inverter correctly for the new addition so it runs with its correct numbers.
I am in LA area and would look for a Shop that understands and installs and configures as well as Battery recommendations.
thanks
Sue.n@gmx.com
FatLady is offline   Reply With Quote
Old 12-12-2022, 06:16 PM   #2
Did you find a shop solving your electrical problem?
I am also looking for a trustworthy shop solving electrical issues.
We're in the same vicinity, I am in Santa Monica, you in Redondo Beach.
Please post reply.
Thanks
snah is offline   Reply With Quote
Old 12-13-2022, 05:13 PM   #3
Once you find out if you truly have a problem in terms of an inappropriate drain, charging issue, whatever. You'll need good battery isolation system that ensures your starting battery and house batteries are set up correctly. There's a wealth of information to be found on this issue here on the Sportsmobile forum:
https://www.sportsmobileforum.com/fo...0-a-26493.html
Even if you aren't a DIYer, a basic understanding of the above will help you sort out whether or not a shop's recommendation makes sense.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Tags
battery replacement, deep cycle battery, electrical shops la
