Update on the light project
I finally got everything wired this morning. All the lights actually work, knock on wood. I did have a couple of surprises.
1-If you see a dual 87 hella relay with one of the 87 posts marked 87a don't be surprised if it doesn't work like you expect a normal dual 87 relay to work. The 87a post is wired directly to the 30 (hot) post and gives you a way to piggy back power to another relay. Don't be tempted to use them even if the pretty blue color looks better than the regular dual 87 relays you bought for the project.
2-The 15A fuses Hella supplies with each of their 4000i hid lights might work well for one light but when you run 3 lights on a single circuit plan on using a 25A fuse. Trust me on this one, 20A fuses last a second or two longer than a 15A but that's about it.
I'll be spending some time tonight aiming the lights. Then it's on to the next wiring project. A dash switch for the Detroit E-locker that is going to be installed early next week.
