[Sorry in advance for the long post]
yes....exactly.
Do you have float set at 13.4 or 13.2V?
The reason I ask is that on the second day you had the batteries at 13.37V.
If float is set at 13.4 than 13.37 would be in bulk territory.......if float is set at 13.2V then 13.37 would still be in float mode.
Float (FLt) is set for 13.2
The Relion Battery Monitor is
not the insight gauge. My battery monitor shows Volts, Amps flowing (+ or -), Ah and SOC %.
When I look at the battery Volt reading taken with a voltmeter off the terminals in the Solar Controller, it is different than the Volt reading according to the Battery Monitor. I haven’t been tracking this, but I did find 2 examples in my notes, and they show a slight difference and on both occasions the Volt reading taken with the voltmeter was slightly higher.
Example 1 13.7 (Voltmeter Reading) 13.39 (Battery Monitor Reading)
Example 2 13.3 (Voltmeter Reading) 13.12 (Battery Monitor Reading)
Are these measuring the same thing
I did plug into shore power for the last couple of days. Yesterday, the Volt reading was 13.6V and SOC was 99.5%, Today, the Volt reading was 14.2V and the SOC was 100%. The Volt reading was the same coming from the Battery Monitor and the Solar Controller. The readings were taken while in the garage and while still plugged in.
Originally Posted by Scalf77
The biggest problem with that is it is just a snap shot in time, you would really need to take measurements throughout the day. You really want to see if you truly reach absorption voltage. Lithium for the most part doesn't hit that level until it is fully charged.
I’m trying to understand the charging modes (as boywonder explained nicely in Post 17) in the context of making sure that I understand what to look for this weekend when I am able to take multiple measurements throughout the day. Here is my current interpretation of measurements that I should be expecting as the Solar Controller goes through the different charging modes:
1. Arrive at campsite. After driving the batteries should be fully charged from the alternator:
- SOC = 100% (based on battery monitor)
- Solar Controller is not in any charging mode
- Solar Controller display lights:
. - Aux Out = On
. - Float = Off
. - Absorption Off
- Volts (as measured by the Solar Controller) = 14.4 (based on the Solar Controller’s Absorption Setting (AbS) of 14.4)
- Amp Out reading on Solar Controller should show 0.0 (no current flowing to the batteries).
-Amp In reading on Solar Controller should show amps being generated by the panels (which will reflect the sun quality)
- All Amps generated by the panels (AMP In) are dissipated as heat through the faceplate of the Solar Controller?
2. Power from the batteries is consumed and the Solar Controller Volt readings gradually drop to 13.2V:
- SOC % (based on battery monitor) = ?
- Solar Controller goes into Float mode. No Solar Charging until Volt level drops to 13.2 (based on the Solar Controller’s Float Setting (FLt) of 13.2). HERE I KNOW I AM CONFUSED: I thought that the FLt setting determined when the Solar Controller goes into Bulk mode? Or, does Float mode start at 13.2V and Bulk mode starts below 13.2V?
. - Aux Out = Off?
. - Float = On
. - Absorption Off
- Volts (as measured by the Solar Controller = 13.2V
- Amp Out reading on Solar Controller should show little to no current flowing to the batteries. Only enough charging to keep the battery voltage at 13.2V (based on the FLt setting of 13.2).
- Amp In reading on Solar Controller should show amps being generated by the panels (which will reflect the sun quality)
- Excess Amps that are not needed to maintain battery Volt level at 13.2V (Amp In minus Amp Out) are dissipated as heat through the faceplate of the Solar Controller?
3. Power from the batteries continues to be consumed at a pace exceeding Amps Out and the Solar Controller Volt reading drops below 13.2V:
- Solar Controller goes into Bulk mode (based on my Solar Controller’s Float Setting (FLt) of 13.2)
. - Aux Out = Off
. - Float = On
- - Absorption On
- Volts (as measured by the Solar Controller is initially less than 13.2V at the start of Bulk mode but will increase during Bulk mode.
- Amp Out reading on Solar Controller should show current flowing to the batteries.).
- All available Amps from the solar panel are going to charge the battery.
4. Solar Controller Volt reading rises to 14.4
- Solar Controller goes into Absorption mode (based on my Solar Controller’s Absorption Setting (AbS) of 14.4)
. - Aux Out = On or Off (depending on whether current is being used in Absorption mode)?
. - Float = Off
. - Absorption On
- Volts (as measured by the Solar Controller is 14.4V
- Amp Out reading on Solar Controller should show a little current flowing to the batteries.).
- Excess Amps that are not needed for Absorption mode are dissipated as heat through the faceplate of the Solar Controller?
- Absorption mode continues for 2 hours (based on my Solar Controller’s Absorption Charge Time Setting (AbT) of 14.4)
5. After 2 hours in Absorption mode
- SOC = Near 100% (based on battery monitor)
. - Aux Out = On
. - Float = Off
. - Absorption Off
- Volts (as measured by the Solar Controller)= 14.4V
6. Return to Step 2
I also found some information about charging Relion batteries from their website.
Relion_Charging_Instructions_022421 (2022).pdf
The instructions don’t seem to tell me much. Just that my current Absorption setting (AbS) of 14.4 might need to be adjusted down to 14v – 14.2. However, I did run across a Relion Blog Post that does list some additional operational parameters for the charge controller and an FAQ with a little information.
Based on these, it looks like Relion is recommending the following settings (compared to my current setting):
- Bulk Voltage = 14V - 14.6 (I’m still unclear how this is set on the Blue Sky Controller)
- Absorption Voltage (Abs) = 14.4 (same as my current setting)
- Absorption Time (Abt) = 0 - 6 minutes (my current setting is 2 hours)
- Float Voltage (FLt) = 13.3V - 13.8V (my current setting is 13.2V)
- Lower Voltage Cutoff = 11V - 12V (I don’t see a setting for this on the Blue Sky Controller)
- High Voltage Cutoff = 14.6V (same as my current setting assuming that this means the same thing as “Maximum setpoint voltage limit” – uPr?)
I was going to make these changes before testing this weekend unless you think I should not.
My plan this weekend is to take readings throughout the day and see what I can learn.
Please let me know if you see any errors in my thinking or if I am missing anything that I should be watching.
Thanks again for everyone’s help.
