I checked the solar output again today. There was a little hazy smoke in the sky so the sun wasn’t as bright as yesterday. Also, it was slightly earlier in the day (started about 1:00) so the sun was a little higher in the sky. I did make sure this time that there was no shade on the panels.
I checked the same as I did yesterday (first with a “normal” load of ~6A and then a second time with a higher load (added microwave).
I don’t understand what changed that could be responsible for the different results. This inconsistency has been my experience. I’ll have a long string of days with little charging and then a day comes where the charging seems great even though there isn’t much change in the intensity of the sun.
Out of curiosity, I then repeated the tests on each panel separately by covering one panel at a time. I thought this would be a way of seeing what happens if an entire panel was in the shade. I was also curious whether there were any differences in the panels.
As you can see, the results were very similar for each panel. This leads me to believe that we can’t assume that yesterday’s lack of charging was due to the front panel being partially in the shade.
Today’s results were much better than yesterday and showed that I was getting good charging regardless of the power load.
Here are some thoughts that I had but, unfortunately, they aren’t giving me any hints at a solution:
· Based on my Voltmeter readings taken from the solar panel terminals on the solar controller, PV was lower today (17.49V and 16.65V) vs (22.08V and 20.21V) yesterday. Does this have any significance?
· Battery voltage was higher today (13.7V and 13.39V) vs (13.15V and 12.91V) yesterday.
· Shouldn’t the lower voltage yesterday be more likely to cause the Solar Controller to go into Bulk mode?
· Today, I was actually getting amps in/out under both “normal” and “high” loads. Yesterday, I didn’t get anything under “normal” load. Why does a heavy load affect amps in/out from the solar panels?
· Today the Aux Out light was off and the Aux Volt was at 0.0, while yesterday the light was on and the Aux Volt readings were 13.1 and 12.9. It seems to me that this merely confirms what we are seeing elsewhere. Since the default setting for Aux Out (out) is ch9 which the Blue Sky manual says is for Auxiliary Bat Charge, today was O.O and the Aux Out light was off because all available solar power was being used to charge the batteries and nothing was available for an Auxiliary Battery (which I don’t have hooked up). Conversely, yesterday, no solar power was going to the batteries so all of it was available for an Auxiliary Battery. Unfortunately, this doesn’t explain why.
Next, I was going to try to look through the various Solar Controller settings to see how they match up with my readings. For instance, since my FLt setting is 13.2, why didn’t the Solar Charger go into Bulk Mode yesterday when the Battery Volt readings were below 13.2V, yet it did go into Bulk Mode today even though the Battery Volt readings were above 13.2V? Please let me know if you think this makes sense.
Any thoughts or suggestions you have are greatly appreciated.
Thanks
