Old 11-06-2008, 05:23 PM   #1
Outside light
A fellow SMBer I met in Fresno is testing this light out and sent me this link. I can have him contact those intrested.
http://www.starlightsinc.com/
DaveB
Old 11-06-2008, 07:08 PM   #2
I like the idea, but I'd really like it at about half that price. You'd think for $100 they'd at least include an LED bulb. I might still consider it if it had the same footprint as my current porch light.
Old 11-06-2008, 07:30 PM   #3
Or buy this unit http://www.hobbytron.com/ce-ck0206.html and rig its relay in parallel with your current outside light switch. At under 25 bucks it's the cheapest 12v motion detector I've found. No, I have not tried this myself - our security motion detector is our Dobie.
1993 E350 SMB, 15M, 84k miles - a cheap date
2006 Toyota Prius because we like clean air
2002 Honda Odyssey - can haul lots of stuff
1972 Mercedes 350SL with 4.5l V-8, just because
Wag more, Bark less, Play well with others.
Psomaki is offline   Reply With Quote
Old 11-06-2008, 09:29 PM   #4
I like it, but i dont know if i like it for $100 like Herb said. When the day comes that i dont have any more mods to make i'll get it
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 11-06-2008, 10:27 PM   #5
Starlight Porch Light
This light could be converted to an LED very easily thru
www.Ledlites.com . I purchased this light when we first got our SportsMobile and found it to be very well made , I returned it because it came to me in White after I was told that Black was available and I thought that would be the color that I would receivewhen I placed the order . You may want to find out if they now have them in Black ,
or you could always use Krylon Fusion Plastic spray paint it works very well.
Greggde
Sorry Girls and Boys correct site is www.LEDLight.com
Old 11-08-2008, 12:25 PM   #6
PR
Footprint
Hi, the Smartlight does have the same OEM footprint as your old porch light. I hooked up my new Smartlight in minutes. The company has spent allot of time on R&D and it shows It runs around 89.00 and change. It is a security/porch light and works very well in the field test.Will have more info soon.
Pr
PR is offline   Reply With Quote
Old 11-08-2008, 02:14 PM   #7
Each of my porch lights are roughly 6" x 3.5". The technical specs page for Star Lights states the dimensions are 10.37" x 4.167". Are those dimensions wrong?
http://www.starlightsinc.com/smartlight.html#specs
Old 11-08-2008, 03:51 PM   #8
Greg In Austin's Avatar
I think SMB may be changing the size and location of porch lights. Our porch light is well below eye level and shines to light up the ground around the door. It is also smaller that porch lights I have seen in the past and it is round.
Greg in Austin
Old 11-08-2008, 04:39 PM   #9
A light with "hundreds of lines of programming". Sounds like a bad programmer to me!
PR do you have photos? What year SMB do you have?
Old 11-08-2008, 05:43 PM   #10
PR
Smartlight
The Smart light it a bit bigger, but has the same foot print. If you have a porch light in the past you will have no worries. If not just move your Smartlight a little to the left or right and you will still be able to cover up your old holes. The light operates just like your security light at home very easy to use............
Jason
Pr
