Old 05-25-2016, 05:24 PM   #11
Awesome info. I'll throw in my experience too which is much more basic. I bought the Renogy 100w kit with the basic PWM controller and no digital display. I really wanted to see how much amperage was coming in so I added a cheap (real cheap) voltmeter/ammeter I found on Ebay or Amazon. With the one panel I see around 5 amps on a sunny day with low batteries. I recently doubled this setup, just adding another 100w panel for a total of 200, same PWM controller and digital voltmeter/ammeter. It immediately jumped to an average of 10 amps coming in on a sunny day, but I saw as high as 12 before I sold the van. Here are the unique things (I think) about my setup. When the batteries are mostly charged the PWM controller lets in less amps, so if I'm not using much or any power my ammeter will go down even in direct sun, which can be confusing. Also, if driving the van and the alternator is charging the batteries the amps coming in drop to near zero on the display, never more than 2-3.
Old 05-25-2016, 11:03 PM   #12
Hi,
I have 2006 e350 Smb with sure power 1315-200 separator. I'm thinking of how I'd run solar on my van. I can't think of where the controller would end up connecting to. Maybe here at the cabin fuse box? Or maybe at the separator some where? Thanks!
Chris
2006 E350 Sportsmobile 6.0
https://phlite.net
phlite is offline   Reply With Quote
Old 05-26-2016, 09:11 AM   #13
Originally Posted by phlite View Post
Hi,
Chris
You can connect the solar controller's battery output + & - terminals to + & - anywhere on the house battery side of your separator assuming that the wiring to the house batteries is sufficient for the planned current.....you can connect the + to a fuse in your fuse block and the - to the ground lug on the fuse block assuming that the wires from the fuse block back to the battery are sufficiently large enough to handle the solar current without much voltage drop.
that's how mine is wired and works fine.....
