Originally Posted by CDACamper
My van has an MPPT solar charge controller hooked up the house battery and the house battery is also connected to the engine alternator (stock SMB set up with Sure Power 1602 islolator). Is it ok to start the engine when the solar system is connected and charging via the MPPT or does this backfeed the MPPT and cause problems/overload/short?
There will be no backfeed from the solar charger to your starting system. You are using 1602 isolator, this is diode based so it would stop current going from the solar to starter.
Once the alternator is charging it will provide charging along with solar. It will not be additional charge, as the alternator will throttle back it charge based on the output of the solar.
If you were using a sure power separator(1315 bi-directional) or blue sea ACR then it could be possible that the solar controller charge was already connecting the two battery systems together, thus you would be starting the vehicle with both batteries. On the Sure Power the start assist could also do this. The Blue Sea ACR can be wired to isolate during start if you have sensitive equipment tied to the house battery.
Again, after the alternator is fully up and running solar and alternator charging can happen at the same time, but it will not be anymore than the alternator could put out (unless your maxed out)
Originally Posted by rizzabove
I have a question regarding the similar part of my electrical system. I have the “Victron dc/dc 30 isolated“ charger. it’s charging my house battery from my starter battery. It does not allow my solar power to charger my starter battery because of the isolator. My question is... can I hook up my solar input on the starter battery side of the dc/dc charger and have the solar power charge my starter battery then run though the dc/dc Charger to my house battery? Or do I just want to replace my dc/dc Charger with the non isolated version?
I love Victron products, but they are late to the table on DC to DC chargers. And then when they do, they confuse it by calling it an isolated DC to DC charger. DC to DC chargers are by their nature isolated, but while they can replace an isolator, separator, or ACR, they don't perform the same function.
They do have a remote on-off, which would allow you to put a charge on the starter and not invoke the DC to DC charger , or force it on. Some new functions probably nice if using their mini-BMS. I'm sure I might have missed something. If your goal is to use solar to charger your house battery with solar, putting on the starter side of the DC to DC charger could be problematic. Especially, if you solar capacity is lower than the DC to DC capacity. It might work but is not really efficient, and any gain your getting by charging starter is negated by the fact that the turn off is 12.6
Originally Posted by BCam
I'm wiring mine as follows:
1. DC-to-DC charger, charges house batteries from alternator.
2. Solar Controller connected to house batteries only.
3. Amp-L-Start, charging starter battery from house batteries. The Amp-L-Start protects the starter battery from overcharging and shuts off when the house batteries aren't receiving a charge from the solar controller.*
*It may not be necessary but I'm installing a relay so the Amp-L-Start won't be connected when the alternator is running since Renogy wasn't sure if it was OK to use an Amp-L-Start their DC-to DC charger.
I would expect that you need to isolate the input of the DC to DC charger while the Amp-L-Start is running when the engine is not running. Again, the output of Amp-L-Start could invoke the DC to DC to fire up and defeat the purpose of the Amp-L-Start. If the Renogy DC to DC charger has a off switch that is possible to tap into or use a high power relay on the input of the DC to DC. If Renogy can't answer that question I would send it back.
