Old 06-24-2019, 09:28 AM   #1
darkstar66's Avatar
Stereo will not turn off
So just recently my Kenwood stereo quit shutting off when key is pulled and door gets opened. I physically have to power off my stereo. It will also turn on when I approach the vehicle with something running through my bluetooth on my cell phone. I also have a Clifford keyless entry/ alarm. It seems everything else operates as normal. I am mostly full time in my van and this has become a pain in the ass. Appreciate any knowledge out there.
darkstar66 is offline   Reply With Quote
Old 06-24-2019, 09:46 AM   #2
gahamby's Avatar
Have you altered the wiring harness recently? I sounds like the constant on power and the switched power wires are crossed.
'07 GMC 2500 6.0
Old 06-24-2019, 03:38 PM   #3
Sboring35's Avatar
Our van has a switch that allows the radio to be used with the keys removed. You haven't flipped it on by accident?
Sboring35 is offline   Reply With Quote
Old 06-25-2019, 08:11 AM   #4
REF
REF's Avatar
Send a message via MSN to REF
Yes, SMB installed a toggle switch, depending on layout and location that read something like “radio- van/house or start/house” that switches the radio from being turned on with ignition (start) over to being turned on with the house battery when parked. Sounds like it’s switched over to run off your house battery. Ours was on the face under the sink on our RB-50
Old 06-27-2019, 10:10 AM   #5
darkstar66's Avatar
Is this switch you are talking about a factory switch?
Old 06-27-2019, 10:11 AM   #6
darkstar66's Avatar
My van is independently built.
Old 06-27-2019, 10:12 AM   #7
darkstar66's Avatar
I had the backup camera replaced but I am pretty sure they spliced into existing wire near the back of the van. I will call and ask if they did anything under the dash although I do not think so.
Old 06-27-2019, 10:14 AM   #8
darkstar66's Avatar
Now my seat belt warning chimes every 30 seconds even though the belt is engaged. Electrical problems are the worst.
Old 06-27-2019, 04:22 PM   #9
Sboring35's Avatar
It was installed by Sportsmobile, yes.
Old 06-28-2019, 04:59 AM   #10
Sboring35's Avatar
this is a picture of the radio switch in our van.
hope it helps,
George
