Old 03-25-2023, 12:22 PM   #1
The_Vermonster's Avatar
Trouble Adding Keyless Entry Keypad
I purchased a keypad off ebay, part number KB3Z-14A626-A. According to Ford and Tasca, this particular model is compatible with E-series vans from 07-15.
I can put the van into "keyless remote programming mode" and successfully pair my current two remotes. I can also successfully set a PIN on the wireless keypad. But I can not get the keypad to pair with the van. I have confirmed that both the remotes, and the keypad are transmitting at 315mhz. According to other instructions I should be able to pair the keypad by simply pressing the "9-0" button to lock.
I'm looking for anyone that has had success with this particular model keypad, or has a solution for similar struggles. I do have access to Forscan but I haven't see a way to manually add a "keyfob".
The_Vermonster is offline   Reply With Quote
Old 03-26-2023, 10:30 AM   #2
Steve Hunt's Avatar
Dont really know specific answers but maybe this will help somehow. I had the Ford dealer do mine. The 2008 E350 came to me with one key fob. I asked my dealer to get me another key fob and also add a keyless pad to mount on the 60/40 door. Here is a pic of the parts packaging. I know they got the wrong keyless pad initially and even struggled slightly with set up (Forscan) but here are the P/N s i ended up with. Part of the Ford part number is identical to the part # you called out above. Cost me $100 for the pad and about a hour labor.
Also the 2021 Ford accessory catalog shows the pad available for the E350.
Steve
2009 KTM 950 Super Enduro
2019 Yeti SB130 Turq Race X01
Steve Hunt is offline   Reply With Quote
Old 03-27-2023, 12:52 PM   #3
Oogs's Avatar
I bought a similar keyless entry pad that was supposed to be compatible with my 2013. Despite many attempts including the dealership, we were not able to make it work.
Try the dealer, good luck
Oogs is offline   Reply With Quote
Old 03-28-2023, 11:05 AM   #4
Steve Hunt's Avatar
I had read that others struggled with aftermarket pads so that's why i just got Ford dealer to provide pad and install. VERY useful when doing activities out of the van with multiple people. Worth the money easy.
Steve
Old 03-29-2023, 08:41 AM   #5
I appreciate the details. I googled your part number and it appears to be the previous version of the keypad I have, which is why they share most of the part number. On the Amazon listing for your keypad there was a comment that the new version (my keypad) has 2 communication protocols and if it doesn't work with one, you need to switch it to the other. I found a PDF with the instructions to change the communication protocol on a Transit forum. It appears they also have issues with the newer version of the keypad. I attempted to make the change, but I'm not 100% confident I was able to make the correct change. My keypad responds differently than the instructions say it should.
So it's not a full solution, but it feels like a step in the right direction. I'll keep exploring and see what I can find.
Unfortunately, on the Transit forum there were hundreds of posts and most said that their Dealers were zero help. That echos my experiences where I can't even get basic help ordering parts from the dealer. I ordered brakes from one dealer online and after a week of no update I called and was told "not to order online because I don't know how to get the correct parts", a few minutes later I got an email that my order was canceled and would be refunded. So I tried another dealer and their parts department was unable to do anything with out a VIN. I told him I had a Quigley with a solid front axle and he said "That's not possible on a E series".
So I'm not going to rush out and give either of them any money at this point.
Old 03-29-2023, 09:42 AM   #6
Steve Hunt's Avatar
In spite of the 4x4 converters saying its all Ford parts and your dealer has the parts , the knowledge, the experience etc etc I seriously feared your experience since you can't even get ATF or something over the Ford counter without a VIN #. When i got my van I went to my Ford dealer and sat with the Service VP, took my list of all the added Ford parts and told what the whole deal was. In that same trip I told him I wanted to schedule Coolant flush, ATF flush, oil and filter also had them replace a few cosmetic parts. A different trip for the keyless pad on purpose. I would normally do all that stuff myself but I was trying to get established and hope they would take a interest in a unique vehicle instead of acting like it was an abomination. They did try to lay down on me once relative to a evap code or something one time and wanted to blame the none stock fuel tank (no no its the original Ford tank just shortened a few inches for the transfer case) After a few phone calls with me that were not heated but certainly warm, they stay engaged and just fixed it rather than looking for excuses. I know its a costly decision but I don't order Ford stuff on line, I use the same local Ford dealer cause i know I'm going to need him to step out of his programmed robot box from time to time. I always say hello to the service mgr and Service VP. Its a little bit of a pain. They certainly recognize the van so that's good.
Steve
Old 04-02-2023, 10:01 AM   #7
GWB
Keyless entry
Installed one on 2014 but could not change passcode, ended up keeping the preset one
Just double check that the original setting might still be active and functioning.
GWB is offline   Reply With Quote
Moby
maptester
Turtle
UrbanDrifter
