Adding 28 lbs of panels will likely benefit from one or two link removals from the extension spring chains, and shimming the helper springs will help a lot for those first few inches of lift.
Shimming/putting blocks behind the helper springs is really really easy and safe and can make a big difference. When the roof is up the springs are just laying in the channels doing nothing.
If you want to try this you just need a phillips screwdriver.
- pop the top
- detach the upholstery behind the crossbars at the rear of the van by unscrewing the screws holding the upholstery down and fold the upholstery out of the way exposing the helper springs and their cover plates.
- you will see the helper springs laying in the channel unloaded, mostly covered by a black metal plate. Grab one and pull it out from under the plate, the spring is either going to be about 1 foot long or 2 feet long.
- Cut a hardwood 2" x 2" block from practically anything and slide it under the plate in the channel then re-install the helper spring. The block pushes the spring 2" forward.
- Pull the roof down and push it back a few times up to see the fruits of your labor. You can make longer blocks for additional spring preload but at some point it will be too much..that will be obvious. From memory, the end of the helper springs need to be 5-6 inches or so from the rear crossbar pivot to be close to their happy place (at least 24" long springs).
This mod is simple safe and easy. Fabricating a spacer will likely be your biggest challenge.
