Old 06-10-2018, 10:45 PM   #11
Glider's Avatar
There are a few folks who use this one:
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 06-11-2018, 07:46 AM   #12
Yup.....using mine right now....it's the cat's pajamas...here is a thread about it..and a grill.....lots of BTUs, excellent flame control.
http://www.sportsmobileforum.com/for...ill-14253.html
Old 06-12-2018, 08:58 PM   #13
Stanvan's Avatar
Many in my circle of friends have the cheaper style of butane stoves. I have a Coleman branded one. I waited for the right time, and it was less than $15 on Amazon. I live in a rental house, that has one of those glass top electric stoves. I hate it to the point that I got a two burner butane stove for daily use. And if you shop around, the butane can be had for cheap.
No one has mentioned this, but butane doesn't work in the cold. A friend lives on a 38' sailboat. His stoves don't work somewhere below 45 degrees or so.
Go Metric, Every Inch of the Way
Stanvan is offline   Reply With Quote
Old 06-13-2018, 05:39 AM   #14
Shuttlepilot noted that butane does not vaporize at 33F, and his graph shows temps at which various gases and mixtures vaporize. Good stuff that I did not know.
I have the Iwatani and agree with others that have positively commented on it.
wish41 is offline   Reply With Quote
Old 06-13-2018, 01:48 PM   #15
shadetreevanman's Avatar
I recently purchased the GasOne Dual Fuel to replace our two burner Coleman. As we already carry propane for our Blackstone Propane Griddle and our Little Buddy Heater. I like having to carry only one fuel type. I picked the GasOne because of the BTU's, and it has not failed to impress. Primarily use it to heat water and make coffee, both of which it can do quicker than any stove I've ever had, including at home.
One of the nice things about any of these little stoves is ease of storage. I built a cubby in my drivers side rear door to store it in, of which I just realized I never took a picture of. Here's a picture of my buddies van door which is very similar to mine.
Tim Potts
Old 06-21-2018, 09:56 PM   #16
I have a GasOne butane single burner and experienced butane freeze up this past winter.
Sooooo, just pulled the trigger fir their 8k dual fuel.
As mentioned above, I also prefer two one burners vs one dual burner
regis101 is offline   Reply With Quote
Old 06-21-2018, 09:59 PM   #17
My Gas One with a Coleman Oven worked good for biscuits while camping this week.
Old 06-22-2018, 03:29 PM   #18
I have gone to exclusively dual-fuel devices. I have a stove and a lantern (and a backpacker's stove) that use standard gasoline from the gas station.
The reason for this is two-fold: first, I always carry at least five gallons of gasoline on my rear bumper. Second, fuel from the sporting good store (e.g. Coleman) can cost upwards of $20/gallon ($10 for a half gallon can).
The stove running on standard gas is a bit annoying because the stove typically gives off a bit of black smoke which can put black streaks on the bottom of your pots and pans; this is because it is not as highly refined as the Coleman fuel. But the stains come off easily during washing.
Chris
cmmitch357 is offline   Reply With Quote
Old 06-22-2018, 05:09 PM   #19
Stanvan's Avatar
FYI, while expensive, that "can" is one gallon. Coleman sells that, and plastic quart bottles of fuel.
Tatonka
gephoto
ClifFord
EliMakes
