Originally Posted by 1der
Keep in mind the bumper is mounted to the stock bumper frame mounting pads. Those pads are designed for impact loads not pulling loads. With an Aluminess front bumper mounting, the pads should have additional welding to add strength.
I just bought a 12K Apex HF winch.
I'm wondering what type of strengthening you would do? The front of the frame has a crumple zone so it probably is the weakest link whether you are pulling or crashing.
The stock bumper is mounted in rubber so those mounting pads are probably not the strongest. So based on your comments the pads in pull are weaker than the crumple zones?
Would you just weld so 1/4" flat plate to the pads?
Additionally is it worth increasing the Alumess plate thickness at the mounts?(e.g. 3/8" aluminum plate )
I'm questioning the strength of the whole setup for a 12K winch and whether an integrated alum bumper and steel trailer hitch would be best advised.
