05-16-2019, 09:54 PM
'04F-250Super Duty 4x4, a donor for '06 E-350?
I have first right of refusal on a '04 F-250 Super Duty 4x4 with blown motor.
This to convert my '06 E-350 Super Duty 6.0. To 4wd.
Seller's Description:
"3,500 obo - 2004 Ford F250 4x4 6.0 Powerstroke Turbo Diesel (Not Running)
Read full post. New Bilstein shocks, 6 month old 35x12.5x17 TOYO AT II, Weld forged aluminum 17x10 wheels, new late model mirrors, newly recovered bench seat, new bestop soft bed cover, new Superchips Flashpaq F5 Tuner, leveled. Transmission shifts perfect and was just serviced with new fluids, both filters, and new shift solenoid and harness. Front and rear axles serviced with new fluid, friction modifier, and gaskets
Considering the lift on the F-250, has 35x12.5x17 tires etc would it be right to assume I'd have most of what I need to do the conversion? I do know I can pick up any and all additional needed parts but am interested to know if I can, with modification use the donor's lift, springs, t-case, running gear etc.
Would I use the front and rear axle to keep the ratios the same etc?
Would I need to swap out the transmission?
Thanks in advance for any input.
09-07-2019, 01:36 PM
I'm using a rear leaf spring from an 04 F250 so the rear spring will work fine. I believe Quadvan uses exactly what are getting from your F250. You have front leafs so you might want to check with ujoint offroad - they have a kit that uses leaf springs both front and rear and uses a lot of F250/F350 stuff so customers can get as much stuff as possible from junk yards.
2004 Ford E350 Extended Van, 6.0L PSD, Quigley, Agile RIP Kit, modified F250 rear leafsprings
2000 Jeep Cherokee Limited 4x4, 2.5" Rancho lift
2009 Keystone Raptor 33 ft Toyhauler
09-10-2019, 09:16 AM
Thanks Egpeil,
That's the way I'm headed kit from U-Joint and use as much as I can off the donor.Storm season in Florida has slowed me down but hope to start cutting in the next month or two.
I'm going to check to see if you have posted any pics ...
Thanks Again
'06 E-350 EB bulletproofed 6.0, '04 F-250 4x4 donor
'88 then '95 Astro Vans turned mobile homes
'79 VW tour bus (The Dead- East Coast 1980's... I think)
1972 Bronco, I sure wish I had checked the oil :/
'69 Schwinn
09-10-2019, 12:02 PM
Yup. It's a good match for doing the U-joint kit.
Trans does not need to be swapped. Only the tail shaft. Yours has likely lived an easier life, considering the tuner that was run on that truck.
Swapping the rear axle is probably a good option, since not only will that match gear ratios, it will match wheel bolt patterns as well, and give you a full float.
You might want to check with Chris @ UJoint about those lifted leafs, and make sure you order the appropriate kit to work with them.
05-14-2020, 09:27 AM
Originally Posted by Phred
Thanks Egpeil,
Thanks Again
I have been setback with some issues of my own. I've done a few things so will add a couple pics but I'm gonna really start into this project in a couple months.
10-19-2022, 12:09 PM
Hello, my friend. I am Jacob. I live in Georgia (country). I am going to build a ford e350 4x4. Can you help me with advice?
10-19-2022, 08:42 PM
The first step is lots of reading and research.
10-22-2022, 04:02 AM
I have a donor f350 5.4 2004 with front leaf springs. Need advice on installing these springs on my 2014 e350. Help with brackets.
10-22-2022, 09:37 AM
Unfortunately that axle isn't really compatible with your an because of RSC.
You would need this kit:
https://www.ujointoffroad.com/produc...-4-w-4r75-rsc/
At that point, you're in almost the cost of a fully installed QuadVan conversion.
10-22-2022, 09:48 AM
Originally Posted by carringb
I know about this kit. But, its cost + shipping cost to my country = an apartment with a sea view))) Therefore, I would like someone to help me with the installation of this bridge and leaf springs. And why won't rsc work?
