It wasn't clear from your post if it leaked just while sitting or if you drove in the rain. If just sitting, it's unlikely the doghouse gasket is the problem. If you drove in the rain, it definitely could be the issue. In any case, it's something to fix.
Colored "construction paper", like kids use, is a great leak detector since it permanently discolors when wet. I assume the current variety is the same, but I'd test it first.
If you tape or stuff some into the various suspect areas, you'll see signs after the next rain. In placing the paper, remember that water travels downhill so make sure that, wherever you put it, you go as high as possible. It can also travel horizontally in unexpected ways.
Bob
2002 Itasca 35U Motorhome
