Old 05-23-2012, 05:26 PM   #1
Gravity based water system?
I am building a ground up Galley for my van with a 36" kitchen cabinet as the base. I found a "bartenders" 15" sink at Lowes and there is plenty of room in the cabinent for tanks and pumps. BUT, I had a momentary bout of curriosity. Anyone seen a gravity feed water system?
I have a porcelain water dispenser I do not use. Simmilar to these
What if I put a fitting on the dispensor instead of the spigot and plumbed it into the sinks cold faucet from there? Would eliminate pumps and switches for water, and flow would be controled via the normal tap handle.
I would have to find a place, at least on top of the counter, to mount the 3 gallon reservoir and dispensor but at least it would make water level checks easy and refills as easy as flipping on a new bottle. Plus it could free up space under the sink for supplies or my battery.
I also thought of mounting a flat tank against my roof for more pressure.
Elfmaze is offline   Reply With Quote
Old 05-23-2012, 05:35 PM   #2
Re: Gravity based water system?
I did a quick pressure calculation and it doesn't give me very happy numbers. even with the water level 24" above the faucet it would only be .90 psi not accounting for line resistance. Maby this will not work... or maby skip the faucet(I already have the faucet though) and use the tap off the dispensor directly over the sink?
Old 05-23-2012, 05:57 PM   #3
LenS's Avatar
Do not see how it frees up space. If you are going to take X gallons of water it has to be stored some place. I don't see pressure as a factor, a gravity system is volume (diameter of feed line). It would word but I personally would not want one. Like have my 18 gallon water tank and not having to move jugs around. A 12 volt pump is no big deal....ours is an non pressurized system.
Len & Joanne
The Green TARDIS
Old 05-23-2012, 10:21 PM   #4
If you already have on-board air, you can pressurize those 5-gal bottles using air. Just need to make a siphon tube to reach the bottom.
Old 05-24-2012, 03:41 AM   #5
interesting idea. I do have air. And enough experience with the home kegerator to make it happen. heck, I could probably even use corney kegs for my fresh water tanks.
This is a Day-tripper / road van. Not going to spend much time away from a water source. Just remember the RV's water system being a PITA with leaks, switches, sanitizing and winterizing each year. Just thinking of KISS methods.
Old 05-25-2012, 12:16 AM   #6
Bones_GSXR's Avatar
This is in a SWB Sprinter
Old 05-25-2012, 03:20 AM   #7
very cool! I knew I was not the only crazy one! Guesstimating by the length something that size could hold upwards of 10 gallons, More if its 4", And he has a bit more height to the system which would give him better flow. I have the low roof sadly.
I'm guessing he uses the Tee setup in the right side for filling/ vacuum relief. Cool thing about a PVC Reservoir is it can take pressure better for the air charged system. But that almost defeats my "Simple" ideology.
But, No pumps or electric requirements, and prepping the system for a freezing night is as easy as making sure the sink valve is open.
Thanks for the inspiration!
Old 05-25-2012, 07:40 AM   #8
The plans for the ocean going catamaran I have been building calls for a KISS water supply: a simple ply tank mounted at shoulder level with a tap and a filler cap on top. You really don't need a massive head for useable water flow unless you plan to shower with it. Water is heavy though, so I'd make it small-ish and easy to refill.
Old 05-25-2012, 08:11 AM   #9
After talkign with the boss, She has authorized the water dispensor version with the sink faucet. I'll see if i get useable flow. The good thing about those 3 or 5 gallon jugs is they are easy to sanitize(swirl some Starsan or iodine) There modular and cheap. and there are tons of places that exchange/ fill them with pottable if not spring water. We had talked about putting a black ABS pipe on the roof of smaller size tank as well... hot water? At least in the summer at high sun....
Old 05-25-2012, 08:26 AM   #10
I remember a post on this forum a number of years back (haven't been able to find it) where someone had a sink installed, but the sink did not have a faucet. They owners put a 2.5 gallon water dispenser (plastic Arrowhead type water bottle with a spout) on the countertop, and poured water into the sink if needed. I can't remember if the sink even had a drain, or if the bowl was removable to toss the water.
A very simply elegant water solution in my opinion.
