Originally Posted by Nomadcat
Is that XL storage strictly a SMB option or can I get it elsewhere?
I don't know how much room I'll have down there. I like two spares for the back country - always have carried them. The one spare underneath, combined with my standard length, combined with the extra large gas tank will probably make it tight down there.
Still, I would like to look into it.
One thing I can do well, though, is carpentry, and I'm already plotting stuff out in my head regarding storage.
I am eating up every photo and write-up on this site for ideas and inspiration, though. Thanks for all the tips and photos.
I looked all around for the XL storage option
No joy.
Hit a couple of local shops, they were reluctant to build, and twice SMB factory
RB or Regular body
IMHO yo are going to run out of room soon
XL gas tank, two spares and wanting to keep the interior Spartan
I have a EB or extended body
Under rig I have:
XL storage, two gas tanks, one a 27 gal transflow
I do not know the specs on XL stock tanks
Now you gotta consider at least one 4d battery, propane, grey water
IMHO one 4d is a must as well as propane
Some folks run no propane, no fixed stove, no forced air heater, no water heater
Also some folks have diesel heaters, don’t know if you have gas or diesel
Then we have the poptop / fixed top question
No mention of it in your build
Which leads to roof rack / solar / storage up on rack
With or without a poptop, I would look at XL storage, rear swing away tire
And one tire up top
Which leads to front and rear bumps
Aluminess, high cost, worth every penny because of weight and storage
Then insulation/sound damp the rig
The ONLY mistake I made in my rig was not going to bare metal
And doing a full sound damp job
As for carpentry, cool you can do it
There is “ultralight” plywood and composite stuff that will save you the weight
And not come apart when wet
There are also some steel framed folding beds in the RB50 style and Gaucho style avail
(RB50 is the seat perpendicular to the rig, gaucho is along wall)
You don’t mention electrical/water
Sound damp everything you can
PRE WIRE PRE PLUMB, then insulate, then panel
Even if you don’t use it, a few dollars of wire/cat5/water hose/TV cable wont break you
So, I would ask:
What kind of top you getting?
Your thoughts on roof rack?
Front and rear bump choices?
(steel readily available, way too heavy IMHO)
House battery choices?
Solar choices
(solar should be an intregal part of the master plan, not a add on)
Electrical needs
Generator or not
Gas or desial
Propane needs
Will this be a daily driver, meaning do you need all the space
(like you mentioned the engle fridge)
Just my 1:49 am thoughts
BW out
