Lilnuts,
The 2000 didn't come with the super duty style mirrors, so the holes aren't there. I used the gasket to mark where the holes should be, to fit the mirrors. As I recall, two of the holes lined up, one was off about 3/16", and the fourth wasn't there. Cut the new hole with a step drill and enlarged the off center hole.
The mounting studs stuck out too far for the interior trim piece to fit, so I pulled the studs out and used bolts with fender washers. The trim piece fits over that nicely.
I think there is a thread on here somewhere where other people have done about the same thing. If your van is later (I think 2002 or 2003 maybe) the super duty mirrors were available from the factory, so the holes are already there in the doors. Or you can just swap later doors, too.
