Hello everyone,
I'm obviously new here and found this forum because I have been tirelessly working to figure out how to implement Jim Phypers hydronic heating system.
http://www.solarhaven.org/HPArticle.htm
It obviously seems simple enough but I had to figure out a couple things on my own.
His article was originally written in 1992 so some of the parts that are listed may no longer exist or the names have changed. He didnt list actual part numbers.
The closest thing to a Dayton/Clifton (low amp) fan that I could find is at this sight:
http://www.backwoodssolar.com/catalog/f ... edom%20Fan
Phypers suggest a Hartell pump but almost $500 is a far cry from the $155 he listed in his plan (maybe it's because he wrote it in 1992). The EL-SID units seem to draw the least amp as far as I can see. Every one of these pumps are expensive.
Here is the link to the pump page:
http://www.ecovantageenergy.com/catalog/subcat49.htm
Heater core: Easy enough, found one at autozone for about $50. I had to go in the back room where they keep them and look through the boxes to check sizes. The guy was cool enough to let me do that but after about the fifth box I could tell he was getting a little frustrated (don't know why, he's getting payed by the hour).
Rheostat: Haven't even got that far yet.
Today I'm going to the big "boat parts" store to see what they have 'cause I guess boat guys do the same stuff as RV guys do
Does anybody see one that sticks out to be the best choice?
I'm going to use a plastic storage "tote" box to house everything in.
To close off the system so that the water circulates through only the heater core I will need to add in a bypass valve with a lever so that the system isn't circulating through every pipe in the rig. When water is need for the sink or whatever I would have to manually open the valves to allow the water to flow and then remember to shut them off again for just the heat. I think that's what he meant.
That part sounds like a chore but someone said I could get fancy and install some kind of toggle switch that would do the same thing but I would only do that if I could verify the system actually worked as planned.
Right now I'm running off shore power using a 1500 watt heater and can keep the temps to 68 degrees easily so I'm hoping that the hydronic system can do the same otherwise I will be quite disappointed.
Anybody else have any luck getting there system up?
Thanks!
