Old 02-12-2015, 08:17 AM   #1
schluchtenflitzer's Avatar
7.3 what spare parts for overlanding needed?
As i will go overlanding in a view month (first Africa, so no way to get parts ecept order and wait for weeks...) i am thinking about what spare parts i need to take with me.
I have no space for big/ heavy things and i can say that I am able to repair everything
Mainly i am thinking about taking some sensors and ECU with me. Just only that once the engine/tranny needs essential to stay running.
What recomantations do you guys have?
Thanks for giving me input
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 02-12-2015, 08:33 AM   #2
rallypanam's Avatar
Re: 7.3 what spare parts for overlanding needed?
CPS
Old 02-12-2015, 08:34 AM   #3
shenrie's Avatar
was hoping this thread would gain some info like what your after and be stickied, but it kinda died out
viewtopic.php?f=39&t=11619
Old 02-12-2015, 09:27 AM   #4
E350's Avatar
OEM Bosch frame rail fuel pump and Racor PS120-2 diesel Strainer/Pre-Filter plumbed in before it.
http://www.ford-trucks.com/forums/12...-strainer.html
And I would replace your fuel tank before leaving, because it will likely delaminate in the African heat if it hasn't started already.
http://www.ford-trucks.com/forums/11...fuel-tank.html
http://sportsmobileforum.com/viewtop...mium+fuel+tank
See UJoint's comment on the last post of the above thread.
Old 02-12-2015, 11:04 AM   #5
CPS i have one in spare since i bought this beast...
Racor is ready to go in and i have a 46gal transfer flow tank in so i hope they have not the delimination problem? I also have no idea if it has a pre filter/strainer in the tank. But as soon i will built in a second tank in i have to do demantle it and than i will check it
Old 02-12-2015, 06:06 PM   #6
Originally Posted by rallypanam
CPS
This is the only thing that has ever left me stranded! I would suggest good batteries, and make sure the alternator/s are in good working order, the 7.3 doesn't respond well to low voltage, and a dead alternator,or two will leave you stranded.
01 Eurovan Weekender
04 E350 rb V10 Wigley
macdadmorgan is offline   Reply With Quote
Old 02-12-2015, 06:14 PM   #7
I also have had a PCM go bad, it didn't leave me stranded, but if I was in Namibia, I would have been there longer then I would have liked.
Old 02-13-2015, 08:42 AM   #8
View the subject Field Repairs for more ideas
jaclindavis is offline   Reply With Quote
Old 02-17-2015, 06:51 PM   #9
UJOINT's Avatar
Yes, CPS, fuel pump is a good idea, fuel filters, I'd even bring a vacuum pump.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 02-17-2015, 07:46 PM   #10
The vacuum pump usually does not come with a pulley, so you must carry "pulley puller-installer" to make a field repair. I believe Harbor Freight has them.
quigley
4x4Ken
Margot
FCAshevlle
