Old 11-30-2023, 10:21 PM   #1
Pimpon's Avatar
Automatic gearbox
What's that tube on the box, I don't have one on the other?
Pimpon is offline   Reply With Quote
Old 12-01-2023, 02:20 AM   #2
Its a transmission cooler oil bypass line. Maybe this link will help...
https://www.dieselsite.com/4r100tran...deletekit.aspx
Old 12-01-2023, 08:21 AM   #3
Pimpon's Avatar
I don't really see what it's for, in the end, it's mandatory or not ...
Old 12-01-2023, 08:27 AM   #4
From 1999-2003 the Ford 4R100 automatic transmission had an external cooler bypass tube that redirected transmission fluid from the pump output back to the return line of the transmission. The bypassing of the cooler was supposed to happen until the fluid reached operating temperatures.
Unfortunately, these bypass tubes commonly fail which prevents transmission fluid flow to the cooler. Another design flaw is, even when operating perfectly, the bypass never fully closes. This means not all fluid is ever sent to the cooler... ever.
The result? Your transmission will overheat.
Old 12-01-2023, 11:12 AM   #5
Pimpon's Avatar
Thank you for your explanation, it is better that I remove this tube is that I put the other 2 tubes of the other box ?
