baldwin BT347 is a potential option to the EA026 -
https://ph.baldwinfilters.com/baldwi.../bt347-baldwin
Micron Rating:9.8 Nominal;
27 Absolute
Length:7 11/32 (186.5)
Application:Allis Chalmers, Antonio Carraro, Fiat, Ford, Hesston, New Holland Equipment; Iveco Engines, Trucks
Product Type:Full-Flow Lube Spin-on
Outside Diameter:4 1/4 (108.0)
Includes:I. Gasket: G381-A
Contains:Anti-Drainback Valve; 30 PSID By-Pass Valve; Standpipe
Compatible Competitor Part Number:Fiat 1909101
Thread Size:3/4 - 16
as is the BT238:
https://ph.baldwinfilters.com/baldwi...-filters/bt238
27 Absolute
Application:Kubota, Thomas Equipment
Thread:3/4-16
Contains:Anti-Drainback Valve; 20 PSID By-Pass Valve
Compatible Competitor Part Number:Kubota 70000-15451
Thread Size:3/4-16
https://www.amsoil.com/p/amsoil-oil-...?code=EAO26-EA
we couldn't find a cheaper alternative to the EABP filter series.
amsoil filter specs if you want to compare =
https://amsoilcontent.com/ams/graphs...ilterspecs.pdf
would probably use something other than the P553411:
https://shop.donaldson.com/store/en-.../P553411/20861
Outer Diameter 4.25 inch (108 mm)
Thread Size 3/4-16
Length 5.83 inch (148 mm)
Gasket OD 2.80 inch (71 mm)
Gasket ID 2.44 inch (62 mm)
Efficiency 99% 40 micron
Efficiency Test Std SAE J1858
Anti-Drainback Valve Yes
Bypass Valve Yes
Bypass Valve Setting LR 12 psi (0.8 bar)
Bypass Valve Setting HR 15 psi (1 bar)
Media Type Cellulose
Collapse Burst 100 psi (6.9 bar)
Type Full-Flow
Style Spin-On
try the P551603 - ~3/4-inch taller and more effective filtration:
https://shop.donaldson.com/store/en-.../P551603/20770
Thread Size 3/4-16
Length 6.69 inch (170 mm)
Gasket OD 2.83 inch (72 mm)
Efficiency 99% 23 micron
Bypass Valve Yes
Bypass Valve Setting LR 30 psi (2.1 bar)
Type Full-Flow
Style Spin-On
we've used a donaldson & EA026 & BT347 & FL20251S and the oil pressure with 5w40 and 10w30 in warm and cold temps was above specs.
