Re: V10 dipstick tube replacement - HELP!
If you think the exhaust manifold heat will damage the rubber tube, you can make a simple heat shield from an old soda can. A piece of metal between the two will reflect most of the heat. Just keep it an inch away from the rubber and it should be fine.
