Originally Posted by louie
What size generator do you think I would need to run the tankless electric. The 33degree version vs. the 48degree? Paul from the Austin shop was doing my best to talk me out of the electric tankless heaters. He claimed they can only raise the temperature of the water by ten degrees? Propane seems like the way to go, but seems like a much more expensive option vs. running my generator with the tankless electric when boondocked.
L
Water heating is a huge energy hog. Therefore, any electric solution to water heating that does not rely on shore power is problematic. Also, showers can easily be a huge water hog and can quickly exhaust an on-board water supply (such as my 10-gallon system) if another source is not available. Demand (tankless) water heaters that I am familiar with work by supplying a constant amount of heat and varying the water flow rate to adjust the temperature rise from the water supply temperature. Slower flow equals a smaller quantity of hotter water for the same amount of heat input per minute.
Some definitions:
1 BTU = heat required to raise 1 pound of water 1 degree farenheit
1 Watt (W) = 3.412 BTU
1 KW = 1000 watts
1 Gallon (liquid) = 8.333 pounds (# = pounds)
1 cubic foot = 7.48 gallons
Volts x Amps = Watts (V x A = W)
A home-based example:
A somewhat miserly home shower might be delivering 2 gallons a minute of 105 degree water heated from the 55 degree water main temperature (50 degree temp rise).
2 gal./min. = 16.33 #/min
16.33 #/min. x 50 degrees rise x 1 BTU/degree/# = 833 BTU/min.
833 BTU/min / 3.412 W/BTU = 244 W/min.
244 W/min. x 60 min./hour = 14,640 W/hour = 14.6 KW/hour.
14,640 W/hour / 120 V = 122 Amps supply required for a shower with a demand heater
14,640 W/hour / 240 V = 61 Amps supply required for a shower with a demand heater
14,640 W/hour / 480 V = 30.5 Amps supply required for a shower with a demand heater
Yikes! This is twice what an electric stove and oven would consume with the oven heating and all four burners on high. Obviously this is not considered practicable in a typical home due to the large power feed needed to do this electrically. Typically, an all-electric home would have a tank-style water heater and raise the water temp in the tank over time with a much lower power feed. When the hot water runs out, the shower ends rather quickly!
The above example provides some useful context for evaluating the small Eemax electric tankless water heaters that run on 120V (data from
http://www.eemaxinc.com/assets/files/sp.pdf ):
SP2412 2400W 120V-20A 33 degree temp rise at 0.5 gal./min. (11 deg. rise at 1.5 gal/min)
SP3012 3000W 120V-25A 41 degree temp rise at 0.5 gal./min. (13.5 deg. rise at 1.5 gal/min)
SP3512 3500W 120V-30A 48 degree temp rise at 0.5 gal./min. (16 deg. rise at 1.5 gal/min)
To be supplied by a generator, the constant generator output rating (not peak or surge rating) needs to be equal or greater than the Eemax water heater demand or you will quickly cook the generator. And this is for a 1/2 gallon/minute shower rate with a lower temp rise than typical at home. If you have the ability to preheat the shower water a bit (solar, engine heat?), than the shower can be hot (72 degrees + 33 degrees = 105 degree shower for SP2412 at 1/2 gal/min.), but otherwise your shower will be not so hot. In warm sunny weather a solar shower may do as well for far less investment.
If you already have a generator of suitable size and have the water availability, the Eemax may be useful. Without a generator, the Eemax probably is not useful since the battery demands are prohibitive. Assuming an optimistic 90% inverter efficiency:
SP2412 2400W 12V-222A/hour or 3.7 amps/minute from your battery (18.5 amps for 5 min. shower)
SP3012 3000W 12V-278A/hour or 4.6 amps/minute from your battery (23 amps for 5 min. shower)
SP3512 3500W 12V-333A/hour or 5.6 amps/minute from your battery (28 amps for 5 min. shower)
A 5-minute shower-run-time will take a big bite out of your battery.
My experience is anyplace that I could hook up already has a shower house and I will use it instead. If I am camped remote but can afford the water (or dip it from a lake, etc.), I will use my solar shower; I heat water on the stove if the sun doesn't cooperate. No, this is not as convenient as at home but I am not willing to pay for and travel in a rig that provides that level of service and luxury, especially without supplemental hookups. If I full-timed in cold weather or populated areas without traveller services, my approach would likely be different.
