Old 10-22-2020, 11:00 AM   #1
Broken Penthouse Latch, Replacement Needed
I was camping this weekend and when I was packing up, I didn't have the penthouse nested correctly. As I was trying to latch one of the front buckles, I managed to break the connection point from the lever that connects it to the penthouse.
Long story short, this is off of a 93, anyone know if these have changed over time? Does anyone have a line on replacements? I'd like to buy a set just in case I break another.
Links or some direction is appreciated.
THaley
THaley is offline   Reply With Quote
Old 10-22-2020, 11:26 AM   #2
They changed over time ........but most old tops use J hooks....
A picture is worth 1000 words....
Old 10-22-2020, 12:39 PM   #3
Correct, I am looking for a J-hook.
I have the van down getting some motor work done. Otherwise pics would be attached.
Old 10-22-2020, 09:16 PM   #4
Any other options out there? I called Sportsmobile and they told me they only have production stock of parts and don't sell to the public.
Options? Thoughts...
Old 10-23-2020, 06:28 AM   #5
BrianW's Avatar
Which location did you call? Try the other two. They used to sell then updated version of the latch on the now-closed SportsmobileStore.com website (run by Fresno).
Old 11-05-2020, 10:41 AM   #6
I upgraded my 2004 to the new latches in Fresno last summer. I’d call SMB West.
bobthecow is offline   Reply With Quote
Old 11-05-2020, 01:51 PM   #7
Greetings -- my solution - Home Depot - buy a couple of 1/4 in diameter lag bolts - measure a good hook for overall length - cut off the bolt head with hacksaw - heat the bolt in order to bend the bolt shaft to match a good j-hook - and cut more off if needed, etc. Don't overheat the bolt as it might break when bending - bend in a vise - the extra bolt is in case you mess up the first bolt. Good luck -- maybe make a spare j-hook to travel with --
Russ
Old 11-07-2020, 08:17 AM   #8
Russ
There are easier ways than that.....I did a 2 minute google search....although I'm not sure of the thread size and pitch off the top of my head...but they are larger than 1/4-20.
*I just measured one of my J bolts and they are 5/16-18 thread and about 4.5" long.
https://www.boltdepot.com/J-Bolts_w__nuts_Zinc_plated_steel_5_16-18.aspx
It looks like Boltdepot above also sells stainless J hooks. The link above is zinc plated. You may need to "unbend" the hook a bit and perhaps some trimming to get it to work as well as the stock hooks.
It's rather pathetic that SMB won't support their product by selling/giving you one. Not the support one should expect after someone spends $10K+ for a PH top.
Old 11-07-2020, 08:31 AM   #9
With a bit of internet effort you could save yourself some physical labor by finding a "J-Hook toggle clamp" (DeStaco Clamp) with an appropriate J-hook and just buy one and unscrew the J hook.
The hook end on these is really close.....
https://www.google.com/search?q=j+ho...ih=579&dpr=1.5
Old 11-07-2020, 08:53 AM   #10
..and, of course McMaster has some too.....the ones near the bottom of the page.
https://www.mcmaster.com/j-hook-bolts
I'd try either P/N 98760A110 or 98760A118....may have to cut them shorter...plug n play
